BMW F25 X2 20i came in to replace his chain guides. We also took the opportunity to look into other areas that need to be addressed.
Thank you for the support!
BMW F15 X5 came in to replace the failed rear suspension air compressor pump. Lucky the rear air kelvar balloon were not damage (Replaced abt 1 mth ago).
BMW F10 520i came in to do a full repair. We took this opportunity to sort out every small bits.
The transmission filter pan showed how much debris it carried. So remember to change your transmission fluid & pan.
BMW F10 520i came in to replace his faulty front anti-roll bar. We also took the opportunity to sort out the arms & bushings as they were also worn.
Thank you for the trust & support!
BMW F22 220i came in to replace his rotors to MPerformance rotors. And owner also took the opportunity to upgrade to LCI tail lights as the old tail lights had water ingress issues.
BMW F30 318i came in to diagnose a drivetrain error that has been bugging him. We pinpointed the problem and replaced the turbo. All good and running well!
BMW X1 E84 18i came in for a full repair. We sorted all his oil & coolant leakage. We also make sure that car is back into excellent health. Thank you for the support and trust!!
BMW E89 Z4 20i came in for a big repair job. Car recently receive another good 10yrs, owner wanted the car to be in excellent health. We made sure that car is back to perfect health condition!
Thank you for the trust and support!!
