Our daily ETC....................
BMW F20 116D came in to do some maintenance.
We replaced his rear shocks, and transmission fluid with filter pan. We also fixed some of his coolant leakage.
Thank you for the support & trust!
Doing our best to make sure BMWs are well taken care. It is our job to make sure your ride is in tip top condition! We also provide sound advice on the modification/upgrade available!
Thank you for all the support & trust given! We will work even harder.
With Love!
BMW G30 520d came in to sort out his headlight. One of the DRL wasn't working. This case was on the 17th of June. We were able to salvage and not blow a big hole in customer's pocket. It might not be perfect, but acceptable.
Thank you for the support and trust!!
BMW E90 335i with N54 Engine came in to have all its issue sorted. We made sure that all the oil & coolant leaks were sorted.
In addition, we also did walnut blasting to clean up the choked intake valves.
Thank you for the support!
iwin68ink
