kevinbmw;874170 said:Hello redrex, before I got my car, I was looking for a 523 as well. One thing I noticed usually is that they have this ticking sound coming from the engine. Not sure if it is a common problem but it sounded like a fan belt ticking..anyway the sound usually disappears after its warmed up. However dunno what's the future implication but just take note and always be the first to start the engine when you are viewing.
Anyway if you take care of your ride and send for regular servicing, think the car an run well even after at high mileage. Hope this helps..![]()
redrex;874318 said:Thanks , how about the electronics ? Not sure if there is any common fault that end up stopping by the road side .
nothingman;874272 said:just got my e60 yesterday. omg the electronics to me r madness! too many compare to my previous CTR. haha
Ct13;874218 said:I can only get the spec from sgcarmart. LCI 525 is 218hp, pre-LCI is 192hp.
Anyone can verify?
Have Fun wif the iDrive!!nothingman;874272 said:just got my e60 yesterday. omg the electronics to me r madness! too many compare to my previous CTR. haha
mel7711;874728 said:Have Fun wif the iDrive!!
relaxed;874851 said:think can increase the idling rpm slightly higher to avoid unstable idling. if it doesn't solve, it could be due to other problems..... like, dirty injectors, faulty fuel pump, etc....
yeshe;876485 said:Bros,
Will be getting my e60 pre LCI 525 this Thursday, will be sending to workshop to do all checks.
Anything to look out for or change for a 72k mileage ride? ( assuming 72k mileage is correct as there are no doc to backup, car diagnostics can verify right? )
According to Rod, there is a way to check whether the mileage is correct or not. Maybe u can check with him (under R2D or better still call him/nadia).yeshe;876485 said:Bros,
nothingman;874842 said:i felt tat my RPM moves a little causing slight vibration of the car during idling. Any e60 bros faced this problem before. the vibration may just a little but it can be kind irritating.
yes.. those before between 2004 - 2009 520/523i or 523xl all is e60.. those strawberries from 2010 new model is F10BMWmaniac;881041 said:Saw plenty of 5 series on sales in sgcarmart. R those considered as E60?
mel7711;881103 said:yes.. those before between 2004 - 2009 520/523i or 523xl all is e60.. those strawberries from 2010 new model is F10
davidtch;876704 said:According to Rod, there is a way to check whether the mileage is correct or not. Maybe u can check with him (under R2D or better still call him/nadia).
