SubZero said:Had mine replaced in Dec05. CSA said this is a common problem. They change the motors for both the driver and passenger side. They changed the driver side window regulator too. Now the passenger side window is working up too.
VenomX2 said:How much did it cost to change the motors in the side mirrors?
Gonzo said:Hi Tango,
If your car is still under warranty, let PML know and get them to solve it for you.
My problem was intermitten. When i put to reverse, my left side mirror tipts down at times only... When it's not working i have push the switch to the right then back to the left then it will work.
Informed PML regarding this issue and they traced to a malfunction motor in the side mirror. Got it replaced within warranty.
martmode8850 said:my Nov05 E46 also... after i folded the wing mirror in and out, the motor worked again... thought i could get a warranty, sigh...
Tango said:My side mirror cannot auto tilt anymore. Niether will the passenger side mirror tilt down when I put to reverse.
The switch located at the driver door panel is not working. Malfuntion for a week now.
Anyone experienced this and what is the problem?
jooggie said:gadgets,
the passenger side mirror does tilt. you just need to switch the mirror selector to the driver's side and it will tilt. to switch off, just switch the selector to passenger side.
