Re: Some teaser pics......RA rated hor!!
Alot of bros here think that the E60 M5 steering is about the same pricing as the E46 M3's.....
E46 M3 paddleshift steering is about S$1.1k after discount & it comes with everything complete except the round airbag.
E60 M5 SMG steering is totally different!! Every item have to be bought separate!!........here's the break down for those who're interested.......
Prices are in US$ (estimated retail w/o shipping)
01 M SPORTS STEER.-WHEEL,AIRB.,LEATH.,SMG SCHWARZ #32342282862 US$898.38
02 MOUNTING PLATE STEERING WHEEL WITH BOLTS #32346763375 US$16.85
04 DECORATIVE CLIPS WITH SCREW SCHWARZ #32342282864 US$58.87
10 AIRBAG MODULE, DRIVER'S SIDE #32346761382 US$795.15
You'll need the multi-function steering control if you don't have Sports Steering wheel!!
03 MFL SWITCH, LEFT #61316918496 US$62.22
04 MFL SWITCH, RIGHT #61317835729 US$102.67
05 ROCKER-TYPE SHIFT LEVER, RIGHT #61317836558 US$204.23
06 ROCKER-TYPE SHIFT LEVER, LEFT #61317836557 US$204.23
02 TUBING, COIL SPRING #61316927092 US$12.16
01 CONTROL UNIT, STEERING WHEEL ELECTRONICS #61316953325 US$142.85
08 WIRING SET,STEERING WHEEL ELECTRONIC CTR #61316963422 US$26.51
All pics & reference from
http://www.realoem.com
Try adding up all the above & see how much it'll set you back if you were to buy brand new..........not forgetting you'll still need the retrofit kit that will make the steering paddle-shifting to work with non-M E60!
'The Great White'
