Sound Insulation
Re: Sound Insulation
Ex or not? Bloody run flats r driving me crazy
Yes its marketed as a premium type, performance+comfort kind, something like the bridgestone gr90.
Plus rubber as a commodity keep up price, duno ist just cos of tyres.
I vaguely remember about $2.2k for a set from Hurry but that's like 5 mths back.
The tyres are ex, but Hurry can offer you reasonable so not so tl.
MW;770025 said:
Bloody run flats are damn noisy. I wanna change to PSS liao
run flats are a must change...keke but must confirm whether u wanna change to bigger rims boh before buying in case waste money
rims already 20"..cannot go any bigger liao or will become X5.
PSS....FTW...
but when you hear the costs of PSS.... you might make noise.... expensive.
I think one set of staggered 20" tyres of PSS is abt 3k
(1) If you are gonna remove cats or install DP, dun bother about insulation.
(2) If you are modding ICE, then go for Dynamat. Had it in the E46 cab, partial helped (even with top-up, insulation was lousy)
(3) PSS is good - no horse run. My lao yah hearse running on it.
MW;769615 said:
Yah, heat and moisture and hardening of the compound (wool or dunno what)...
i change cars every 6 mths. will it deteriorate?
why wud a 523 need PSS? u want insulation...n unless u driving crazy all the time...u go with ps3...unless u die die nees pss cos u wanna be known n sporty. u know like fitting BBKs for normal road driving...many admit for swee.
How about Corsas?
Like I said, got BBK, bo li yiu save $$$ on tyres. Simple logic.
The incremental costs of PSS over PS3..... lesser than one night in Sar Lau.
PSS or PS3 quieter?
All I want is reasonably good grip on wet and dry and low noise...
And it seems Eagle F1 Asymm 2 doesn't have 20" sizes...or else I will get those
MW pls order Michelin Pilot cup sports.... best.... most hardcore then mod Yam 5 kit and put BBK....
if still not happy.... pls get your bodykit installer to paint the letters on your tyre sidewalls....
MW;770903 said:
PSS or PS3 quieter?
another tire idiot. pss is 1 up in terms of performance from ps3.
u need to buy the best?
...but no idea best grip in dry means diff compound..means tire need more time to warm up means high lateral grip...means u dun even come close to that in daily driving in a 523....so u r prob better off in a ps3....where it takes less time to warm up..better insulation....n the lateral grip level is still not going to b breach by u....cheaper...n more importantly safer cos it grips better in the wet n it takes less time to warm up.
unless u tell me right now..u need the absolute best model on ur car...thats what i used to do (ie haolian, feel good factor). like most ppl buy BBK on their 523 530 etc....but the only real reason for BBK is that it stops more consitently over longer periods of hard braking than stock brakes....which u never at all in day to day driving.
fromwhat i know about ur needs n how u drive..stick with the ps3. dead quiet..last longer..u still will never breacked its limits in a 523....clears water better..warms up easier for daily drives....lasts longer...n still a damn premium perforamnce tire.
I never said I needed to buy the best, I only wanted something good and quiet and not some lok kok brand..and since when did I say I am buying BBK?
And whats this about 523 530 and simi car? So you are saying a toyota just use lousy tyres can liao?
Come on lah, not everyone is as intelligent as u and for tat I salute u...
If it will make u happy, I will stick to my RUNFLATS for my lowly 523
im not hooting u. i m telling u my personal experience when i had that 530. i only when for the best ps2 tires etc..just for feel good. n i realised along the way that i never came even close to its capabilities. it was all for gratficiation. since i had bbks n exos n all that i wanted to hv the 'best ' tires....
but if u saw my xplanation on that corsa thread..u wud know that along the way i learned that in my 530 or gti or even the lamb..i iwll hardly reached or breached the limits of a ps3.
the lamb i will stick to corsas cos i do track them n i know i need them...but im sure u read how long they take to heat up.
if kenn tells me he has the 335..n knowing how he drives, i will ask him go PSS...in his hearse now pss works.
bro im giving u the best advise i know. if its for feel good n u want pss, i wun discourage u. but here we r talking best insulation. u also included that wet n dry grip important. n hence i suggested ps3. i know u n ur driving wun be as nuts as ah pui or myself. save some money, n u buy some safety as well....most expensive tires, best grip in dry etc....only applies in xtreme conditions....for u, the car, ur driving, ur needs...my opinion is that the ps3 suits u better. dun need to suan me...cos i only tyoed here to share.
Ok swee then I buy ps3
And I really read your advice ok!
pg88comim
