drift838 said:Have been quoted $250 for eibach 10mm spacers, but they don't come with bolts.
Are they supposed to come with the bolts?
If I want to maintain the OEM look by retaining the OEM black bolts, are the bolts too short?
Wonder if BMW has longer bolts?
Thanks for any advice.
BlackStealth said:Go to SE tires! They provide bolts when you buy their Eibach spacers from them. You cannot use the stock bolts. Too short.
louis said:$250 is for a set of 2. as for fitment, i think whatever spacers can fit the e46 should fit the e90 as well
Hi TripleM,TripleM;107990 said:Then drive carefully...
Anyway,
Ur ride is E60 rite?
AFAIK, the spacers he got for you was for E46 so slighlty different center bore diameter and had to be modified slightly for E60 application. I guess that's why he told you not to try too much of a high speed run.
