taizi_dominic
Users Awaiting Email Confirmation
my spare key doesnt work...how? cannot lock or unlock...starting the car is ok though...read this online..wonder if it works?
Definitions: button 1 on the keys is the one closest to the metal part of the key (this is the door open button); button 2 is the middle button (the door close button).
1. Open the car doors using the remote function of your working key.
2. Get in and close (don't lock) all the doors.
3. Put the key in the ignition and switch momentarally to position 1 which is the first position when you turn the key clockwise. This is the accessory position. Don't stay in position 1 longer than 5 seconds; then turn the key back to the off position.
4. Remove the key.
5. On the key transmitter, press and hold button 2. Press and release button 1 three times within 10 seconds while still pressing button 2.
6. release button 2.
7. The system indicates re-programming by locking and immediately unlocking the door locks.
8. If you want to do more remotes, you must do each within 30 seconds of step 7 for the preceeding key. You just need to repeat steps 5 through 7 for each key after the first.
4. Remove the key.
