Upgrade to LCI bonnet and M Sports bumper after hitting monkey on NS highway – E90
Re: Upgrade to LCI bonnet and M Sports bumper after hitting monkey on NS highway – E9
Hi Aaron, can share your contact in Malaysia and Spray Paint ?
Thanks
Javier Zhang;1043537 said:
Hi Aaron, can share to me the contact for the dent removal guy.
PM u already
Hi
Like to check with u ppl. Car still in the workshop. Should be able to get it back tmw.
As i have also changed the side skirt for the LCI one. Was told by the workshop that when installed the LCI side skirt, there is a slight bigger gap between the side skirt and the door i think..... Was told that need to change some inside bracket to 'solve' the alignment issue. Is this true? Or anyone can advise?
One more qns. Itchy side. read that the radio and air con control knob can be easily changed right? Is this easy? wanted to change to the LCI one with those chrome one. how much will it cost?
Thank you.
Cochran;1044570 said:
Hi
Thank you.
I did not change my side skirt.
But if some brackets can solve the gap problem, it should be very cheap.
Radio knob u should call up stockies to check for the best answer
Aaron, my respect for you for the lobang you have... Car looks as new now! Congrats!
Bro, can pss me the address of the Pandan Loop workshop where they do your HID rings? Damage?
Ok, PM u now
Hi Ppl
Just collercted my car on sat. Sianz. got a few issue.....
1. Now the car direction indictor light left and right when signaling the speed will be very fast. why? History: The workshop told me when they installed the LCI rear lighting, the reverse light dun work. Installed back the old light it work. Then they did some mod of the wiring on the LCI light and its working now. But now i face with a super fast speed indication lighting and a light error on my car. Just told by friend this morning that its something to do with some wiring resistor not added or removed?
Here is a video of the light speed
[video=youtube;ljDmOM6_4OM]http://www.youtube.com/watch?v=ljDmOM6_4OM&feature=youtu.be[/video]
2. The side skirt not aligned. Something to do with the bracket. So need to change it.
Here is some of the pic
View attachment 56352View attachment 56353
Cochran;1045216 said:
Hi Ppl
looking good n shiny!
Hi Cochran,
You may need to get your rear tail-lights program properly after upgrading to the LCI tail-lights.
There's a FL guy that knows how to do it, PM me if you need the contact.
The side skirts do require a LCI bracket, but shouldn't jut out much if you don't mind it that much.
Hi all
have got in contact with red bean bun to help me to code tml.
The shine on the car is after a full complete respray of the car and using of the SONAX Brilliant Shine Detailer.
Got the workshop to help to check how much is the side skirt LCI bracket. See if the price is ok or not.
Now.... Dun know to be itchy or not to change to LCI side mirror. ha.
Nice.. LCI xenon headlamps to complete the look
To ex to change to xenon. On LCI halogen headlamps already.
U can try Ebay UK, I ordered mine 2nd hand there for the Pre Fl xenon headlamp definitely much cheaper than stockie here
Hi ppl
Is the item 6 the side skirt bracket that i need to change? So ex at $280+ in USD or watever currency? Hope its not that.......
Or izzit some plastic clip? Which the workshop got for me wrongly or used back the old one? Lik in the pic?
Hi Ppl
I happen to like the speed ur signal is. Ha ha.
Sorry I have no idea how to solve this.
The side skirt brackets and clips are as cheap as $12 from stockies.
PM me for the contacts
Hi Aaron
Can i know what is the cause of the alignment issue i have now after replacing to LCI side skirt? Do i need to change the brackets or the clips or both?
THe clips are the one in yellow fr the photo?
Thank you
Cochran;1046532 said:
Hi Aaron
Thank you
No idea sorry, I hope some brothers and sis here can help?
I am using my original side skirt
Upgrade to LCI bonnet and M Sports bumper after hitting monkey on NS highway ...
Hi Aaron
Thank you
Don't think its as simple as the clips. You may want to go down Eng Soon to look for Michael.
Ask him to help you compare the LCI and PFL side skirt bracket, that's a high suspect.
I am using the PFL bracket, juts out a little but I can live with it. Do let us know if you found the solution later.
okbetcasinocomph
