We Live and Breathe Bimmers
Do you see what's wrong with this shock absorber?
Shock absorbers are parts of the vehicle suspension that absorb shocks from the bumps and potholes and keep your vehicle riding smooth and stable.
If you notice your vehicle swerving or "nose-diving" diving while braking, there's a chance your shock absorbers could be failing.
You may also notice that your car swings up and down more, like a boat.
Don't hesitate to bring your car in with us to inspect if you suspect there could be anything wrong with your suspension!
This is a very common door seal wear in the 2 series Active Tourer and Gran Tourer.
This door seal is responsible for your cabin dry and quiet. If the seals are left to degrade, it may get to a point where you might notice more wind noise or some moisture seeping through.
Fret not, we have the solution for this! Head down to our workshop and we'll be happy to serve you
There could be many reasons if your steering wheel vibrates when you brake.
It could be dry guide pins, worn brake pads or worn rotors. In this particular car however, we found that cracked control arms mountings were causing the problem.
If your steering wheel is vibrating while driving, don't ignore as this could be a sign.
We're happy that our customer's car is all good and he can drive home in his excellent ride.
This is a car that suffered from an engine mount leak as you can see here in the photo.
When the rubber part breaks or separates or when liquid starts leaking out of the liquid-filled mount.
Common symptoms of a failed engine mount is the increase in engine noise and vibration felt inside the car.
We are happy that this issue is fixed and the ride is now all smooth and gained back its luxurious feel.
If your F10 or F07 or F02 carpets always get wet (usually on the left hand side), chances are the rain water may have leaked into the cabin from the firewall cover.
Fret not, we have the solution for this. DM or message for no obligation enquiries.
Our customer complained that aircon not cold and we found the aircon gas level was very low upon inspection.
Here is a sneak peek of how we've had to dismantle the whole dashboard to replace the evaporator coil with pipes and condenser with dryer (all original parts).
Customer was given a rental car for replacement while we work on this baby
Ever feel that "lag" when you step on the accelerator and your car takes a second to pick up?
Experience significantly sharper responses for your car
pedal with the RaceChip XLR. Installation is fast and quick and is completely reversible.
Available for any car equipped with an electronic throttle, regardless of whether the engine is naturally aspirated, turbocharged, supercharged, electric or hybrid.
Comes with phone app to control your throttle sensitivity.
PM for more enquiries.
Customer complained that he hears clunking noises undercarriage.
Clunking noises are symptom of possible problems with the control arms on a vehicle.
Another common symptoms associated with worn engine mounts are impact noises coming from the engine bay. Worn motor mounts can cause clunking as a result of the engine shifting excessively.
We are happy to get this car fixed and all ready for the road now with the utmost comfort and luxurious feel.
Transmission overhauling in action.
Car unable to to move when gear is engaged. Check transmission fault warning ⚠ light is on.
Every part of the transmission is inspected for wear and damage, and then it is cleaned in a special cleaning solution, or replaced with another part depending on its condition.
If you have any questions about transmission overhauls or would like to bring your vehicle in for a transmission repair, feel free to contact us and we’d be happy to help you out!
Replacement of control arm, lower arm and stabiliser link for both front sides done for this baby.
When do you replace them? Here's a few symptoms to look out for:
- Wheel alignment difficulties
- Vehicle won’t track straight or pulls to one side
- Clunking or squeaking noise
- Vehicle pulls to one side only when braking
Feel free to bring your lovely ride to us for further inspection if you suspect any of the symptoms above.
This baby had her oil feed turbo pipes replaced.
It is essential that there is consistent flow of clean oil for any turbo. Todays turbos operate under great pressure and high temperatures of over 950 degrees!
This means your oil is placed under heavy demand and even slight contamination can cause problems to the turbo.
We're happy that this ride is running at its optimum performance
A quick look at removing the gearbox for transmission overhaul due to failure :(
Most common issues of transmission failures are leaking transmission fluids so always be sure to ensure that your fluid levels are sufficient.
