We Live and Breathe Bimmers
We have our skilled technician Choong checking and troubleshooting top convertible functions on this sweet ride.
If you notice that your ride has gotten bouncy recently, it is probably about time to replace your shocks.
Your ride should be as smooth as butter & not bounce or sway when going over humps and cornering.
We are happy to replace this sweet F10's front leaking absorber and worn out lower arm and the car is back to its luxurious feel.
What happens when you have a bad Vanos unit?
Look out for symptoms like diminished performance, low fuel economy and rough idling.
However replacing various Vanos components isn’t an easy task. The entire system must be taken out of the engine. This takes BMW-specific skill, expertise, and experience.
Contact us if you face the symptoms mentioned for us to inspect your ride.
The installation process of dismantling a dashboard and installing a brand new one after a car accident.
Its interesting to see how the airbag systems is fitted into our modern cars.
As soon as the car detects a frontal shock at 25km/h or more at which the seatbelt is no longer enough to protect the passengers, the airbags is deployed within 50 milliseconds – that's less than a blink of an eye.
If you notice exhaust smoke coming out of your car, there's a chance that the oil has leaked into your combustion chambers due to bad valve seals.
Another symptom to look out for is the loss of power. We will do compression test to help pinpoint whether its the valve seals or the piston rings that's causing loss of power.
With Juzz Performance, we will be more than happy to diagnose issues to ensure the best for your car.
Contact us today if you suspect any issues with your car!
Oil coolers keep oil temperatures at its optimum level. The longer oil stays at its optimum temperature, the longer your engine and gearbox will last. Look out for of symptoms bad or failing pipes such as engine overheating and oil leaks.
We are glad to have replaced the leaking pipes from this sweet F10 and glad to have it up and running smoothly again.
If you face bumpy rides while driving your car, chances are your shock absorbers require replacement.
The car should bounce up and return to its original position rather stiffly, without continuing to bounce. If it bounces more than a couple of times, this is an indication that perhaps the shock absorbers are weak.
An A4 came in with excessive white smoke when accelerating. Upon further inspection, we found that piston no. 2 has a low compression and was cracked reading after doing a compression test and visual check.
Rectification was to do complete engine overhaul.
A cylinder head gets cracked due to most common reasons such as overheating caused by coolant loss, head gasket failure or restricted flow of coolant.
