We Live and Breathe Bimmers
A sweet cherry red 1 series in the house. :cool:
We're always happy to serve your rides.
This lovely Volkswagen Golf Mk7 had the Racechip GTS and Jetex Sports Filter combo installed.
With the Racechip GTS tapping into unleashed power reserves in the engine to increase up to 30% more horsepower and the high-flow Jetex Sports filter effectively improving the engine performance, this duo is a killer combo.
PM for enquiries on your model.
In this rainy season, you might experience some water leaking from your sunroof. There are various reasons why this could happen. Most commonly it could be a clogged drain or perhaps a worn seal.
The main thing to remember when maintaining your sunroof is to keep any debris out from the train such as leaves, twigs and other dirt. A simple thing as a leaf can clog a drain tube and cause a leak. Mold and mildew can also form in your vehicle if the leak is not taken care of.
If the problem still persists, there is a chance you might have a worn seal. You might want to get it checked if that happens. At Juzz Performance, we are always happy to diagnose and solve your problems :) Feel free to contact for enquiries.
Our technician Hou troubleshooting a BMW 640 cabriolet that had water leaking into the car while it was parked outdoors during a heavy rain. The most common causes for water leaks in cabriolets are mainly drain blockages.
When water lands on your cabriolet, its directed through the drain and out to the roads. Unfortunately, these drains can become blocked by debris such as leaves and twigs if they are not cleared regularly. Other causes can also include:
1) Aging seals
2) Torn or damaged door membranes
3) Old and aged fabric hoods
The most reliable way to care for your vehicle’s folding roof system is to have it regularly serviced. This will ensure that your vehicle’s seals and mechanical components are in good working order.
Engine mountings are responsible for for securing the engine to the vehicle chassis. As the engine generates a considerable amount of vibration during your drive, the engine mount absorbs the vibration and you experience a smooth drive.
Here are some symtoms to look out for when your engine mounts are wearing off:
1) Clunking noises coming from the engine bay
2) Excessive vibrations
3) Misaligned Engine
Here we found that the engine mounts in this Mini were cracked and leaking. When these engine mounts fail, not only do you experience an uncomfortable ride but it might damage and place additional strain on other components.
If you experience any symptoms of the above, its possible that you might have a worn mount. Feel free to contact us for any queries.
What you are seeing in this video is a power steering fluid leak. When you face a leak like this, your steering will start to become heavy and difficult once it loses fluid pressure.
If this happens when you’re driving on a relatively straight road, it won’t make much difference. However, if you need to turn, especially if you are going at speed, it will not be easy or safe.
The causes of leaks can come from loose fittings, cracks in the flexible rubber hoses or worn seals. Environmental conditions and driving styles can be a factor as well.
The main thing to look out for is small red or pink oil puddles under your car. If you see such a puddle, it could be a possible indicator. Feel free contact us for more queries if you suspect anything wrong with your ride.
Another sweet X1 that had the Racechip XLR installed.
Experience significantly sharper responses for your car pedal with the RaceChip XLR without having to feel that "lag" when you step on the accelerator.
Racechip XLR is completely reversible and does not void warranty – which is why it is the go to option for many enthusiasts.
Complex technology. Simple installation.
PM for enquiries on your car model
Your valve cover gasket is one of the most important gasket that keeps your cylinder head from elements and prevents oil from leaking.
As with all wear and tear components, your valve cover is bound to wear over time and will cause oil leaks and a reduced engine performance.
What are the symptoms to look out for valve cover gasket leaks?
1) Burning oil smell
2) Dirty valve cover
3) Engine oil light on dashboard
4) Rough engine
If your car display such symptoms, there is a possibility of a valve cover gasket leak. Feel free to reach out to us and we will be more than happy to troubleshoot and diagnose for you!
A transmission overhaul in progress, including a new set of clutches, transmission oil & oil pan with filter. When do you need to do a transmission overhaul? Generally, these are the following symptoms:
1) Constant transmission fluid leak (even after repairing seals)
2) Transmission won't shift into gear (possibly worn or damage gear teeth)
3) Strange sounds coming from the transmission
4) Burning smell from the engine
While this list is not exhaustive and conclusive, it is important that you do not ignore these signs. Be sure to get it checked before other components are damaged further.
We service all German makes and models. Contact us for any queries with regards to your car.
Remove bad odour and disinfect your car from bacteria!
Introducing the Anosan Eco. With this, we will completely eliminate bad odours and disinfect bacteria from your car.
How we achieve this is through utilzing cold fogging to completely remove odours and dust while naturally disinfecting viruses in hard to reach areas in your car which is often not achieved through traditional surface disinfection.
This product that we carry uses patented ECALIT technology monitored from Germany containing the highest grade ingredients to disinfect your car ensuring the highest standards of hygiene.
Bring in your ride to us and we'll disinfect your interior just like its out of the showroom!
Two beasts in the house having the KW suspensions installed! Your suspensions are a crucial part of your car. It maximizes the friction between the tires and the road to provide steering stability and good handling. When do you need to replace your suspensions?
- Uneven wear on your tires
- Harder to steer
- "Nosediving" when you brake
- Bumpy rides
If you face any of the symptoms above, its very likely that you have a worn suspension. Contact us for queries on your car!
Complex technology. Simple installation. PM for enquiries on your car model
Here we are replacing the torque converter oil seal due to a transmission leak.
If you notice a small puddle of red fluid underneath your vehicle, this is not a good sign you and need to get the leak repaired. If it is left alone, the problem will get worse over time. Eventually, the transmission will fail if the leak is not fixed. A smaller leak is a simpler fix than a bigger one so always be sure to rectify the leak early.
Contact us for any queries about your ride and we'll be happy to serve you!
TA compliant Eisenmann exhaust installed with single tip on both sides and Carbon fibre diffuser to give a nice finish.
DM us for an exhaust upgrade.
*Picture taken before circuit breaker period. We are taking orders only and will carry out installations after circuit breaker period.
We installed the ST Coilovers on this sweet A4 Avant.
Improve your car handling and let your car "hug" the road. With the ST coilover kits you can perfectly adjust the look of your vehicle to maximising the performance of your car with adjustable rebound damping and adjustable top mounts.
DM us to discuss for a suspension upgrade.
Transmission oil leak repair in progress!
If you spot a green or reddish fluid puddles forming under your car, chances are you have a transmission oil leak. Usually the main cause of a transmission oil leak is a gap in your transmission. It can be tricky to narrow down where the gap is as it could be in a pan gasket, torque converter, fluid lines, transmission pan or the seals.
Transmission oil leaks can occur due to various reasons such as wear and tear, damaged by debris from the road or loose/broken seals.
As mentioned, if you notice a green or reddish puddle forming under your car, even if it's just a small amount, you must get the leak rectified. If left alone, the problem will worsen over time and your transmission will eventually fail.
We are Juzz Performance and we are a German car specialist. If you notice any such problems with your car, feel free to contact us and we'll be happy to help you!
cyberfreaker
