We Live and Breathe Bimmers
This Porsche Cayenne Diesel had an engine check light on due to a choked diesel particulate filter. This is fairly common if you only do short trips and don't go over 60-70km/h often as the filter may clog up and hence cause it to choke.
For this issue we used the TUNAP Diesel Particulate Filter cleaning solution. If you face any issues with your car, call us for a consultation and we are more than happy to serve you!
Installing the DV+ Performance Diverter Range by GFB!
On earlier VW/Audi engine models, the diverter valve has been always a weak point. They commonly used diaphragm diverter valves which had the tendency to tear or leak – this makes it so that the turbo can't hold boost well.
GFB’s DV+ diverter valve range offers a direct-fit performance solution for the weak factory diverter valves used on many modern vehicles.
By retaining the factory ECU control and recirculating the vented air, the DV+ is a purely performance-oriented product that offers the following benefits:
1) Sharper throttle response
2) Faster boost recovery on gearshift
3) Solves boost leaking issues
4) Built to last
Contact or DM us for queries and we'll be happy to serve you!
Replacement of front ST shock asorbers.
Your car’s shock absorbers do more than contribute to a smooth ride. In fact, their primary purpose is to help you maintain control of your vehicle by keeping the tires on the ground on bumpy roads.
As your shock absorbers wear and tear over time, here are some key symptoms to look for so you can educated decision as to whether or not you need to replace them:
1) Vibrations while driving
2) Swerving or nose diving while braking
3) Brakes take more time to stop the car
4) Uneven tire wear
5) Leaking fluid on the shaft of shock absorbers
6) Cracked bushing at attachment points
If you notice any of the symptoms above, it could be a sign that you need to replace your shocks. Feel free to contact us for queries and we will be happy to help.
Out with the old, in with the new spark plugs!
Spark plugs even though they are small, are probably one of the most critical components of your car. Without a spark, there would be no way for fuel to ignite in the combustion chamber. Below are common symptoms to look out for to replace your spark plugs:
1) Engine light on
2) Slow acceleration
3) Poor fuel economy
4) Engine misfiring
5) Difficulty starting your car
Just like other wear and tear parts, spark plugs need to be regularly replaced. If notice any of the symptoms above, its probably time to bring in your ride to get it checked.
BMW 740 G12 RHF replacement due to air leak from air suspension.
One of the most common air suspension problems is a deteriorating air spring. Over time, the rubber components tend to wear which creates small holes and tears causing an air leak.
There are various signs that you can look out for that your air suspension is leaking. For example, you may experience bumpier rides, the air compressor constantly running to keep the springs inflated and your car sagging to the side where the leak is.
If you notice any of the symptoms above, it could be a sign that you need to replace your suspensions. Feel free to contact us for queries and we will be happy to help.
FTP Charge Pipe installation done.
The brittle factory plastic pipe can fail under increased boost pressure with your turbo-charged BMW. With the mandrel bent aluminum FTP Charge Pipe, the reliability and flow is greatly increased. The increase in pipe size also helps to reduce turbulence and maximize flow into the engine.
PM us for queries and upgrades.
Before and after installing the Eventuri intakes.
The Eventuri intakes provide an aerodynamically efficient airflow path from the filter to the turbos. It is not just another cone filter with a heat shield but a unique design which invokes the Venturi effect and maintains laminar flow conditions to reduce the drag on the turbo.
Contact us for an intake upgrade.
Experience significantly sharper responses on your car throttle pedal with the RaceChip XLR without having to feel that "lag" when you step on the accelerator and unlock your engine’s maximum performance to up to 30% more HP and torque with the RaceChip GTS.
Racechip is completely reversible and does not void warranty – which is why it is the go to option for many enthusiasts.
Complex technology. Simple installation.
PM for enquiries on your car model
Range Rover Sports K&N High-flow air filter installed.
Designed to allow up to 50% more airflow than traditional paper filters—and greater airflow can result in an increased horsepower and torque output.
DM for queries.
Replacement of con-rod bearings for E92 M3 S65 engine.
It is always better to replace your con-rod bearings before they get entirely worn out. (Which may cause the entire engine to break down)
Preventive maintenance is key to a longer engine life and greater cost savings.
We specialize in maintenance and servicing, tuning & repair of German makes.DM us for queries.
Replacement of valve covers for E92 M3 S65 engine done.
As this is a high performance engine, the valve cover tends to warp due to heat which would then leak to oil leaks.
The warping valve cover is a common issue for this engine. Look out for oil stains on the floor and on the engine. Get your car checked if it’s losing too much oil.
DM us for queries.
cyberfreaker
