Red_Bean_Bun
Re: What intake are you on?
Gruppe M - for both noise and gains .......
SUPAN;1090380 said:In my humble opinion air scoop are not useful on my 335
Sold it away within 2-3 days ...
Maybe helps on the low low torque...
If you travel 240 I not sure if the scoops holds in place ...
Partly true... it depends on your mod.Hurricane;1112799 said:Hi Guys,
with the current TC range of BMWs, the original engine air filter element actually has enough surface area to breathe but dependent on the media. If its paper, its ok, if its K&N, you need to ensure you keep it in good shape as in not too much oil. As for pod filters, only go for it when you rev above 3,000rpm or so.
Without a good intake, even you put up a good exhaust, you may not be able to breathe well. Its like running 2.4km with a N95 mask.
hmmmmmm.......... But that would "wreck" the tuning right?There is no such thing as legal down pipe. Some people swap them out to stock before inspection, then after that replace back after inspection.
You may be right but I'm no expert on tuning. People who do this swapping of down pipe for inspection is normally on PiggyBack (no tuning disruption issue).
