What is the first mod to do for the F10?
Re: What is the first mod to do for the F10?
casper77;1097425 said:
it wasnt me.... yang ask me to do so....
when i grow up i also wan ah peh f10
How come when i grow up, LTA send me a notice that my E60 is due to scrap?
Jason8822;1097416 said:
Din really check.
But i reckon the gap seems so big here cos the road is uneven.
However, left side is significantly higher than right.
Mine is also slightly higher on left...about same as your 2nd photo.
According to some experts conti cars are made with left hard drive in mind thus all weights are shifted to the right to balance out. However for us right hard drive cars have the driver side inverted thus causing this imbalance. Dunno how true.
Got my f10 not very long ago, changed my rims... Now just came back from infratint, not after reading this topic...
Very true.
Absolutely true.
Whatever 5er you have, the mod poison here are endless. You just need to find the poison spring to keep poisoning non stop. Need poison contacts, pm me.
Nope...not poison. Are viruses. Depend on your antibodies. ..if u kana hard....u will automatically become a carrier.
Wahahaha .... luckily i have lots of inborn antibodies
U cb lar...I use up all my power liao...u are now free....
What to do. Chick will not become a swan no matter how you groom it. Sorry to let you down.
A set of good rubber, 18" rim with Continental or Michellin rubber at 275mm width, good grip, wide enough, much lower cost than 19" or 20", better absorb bumps and holes, reasonable look.
What's the correct rim size and offset for 18 inch rim and profile for 275/18 tires ? Any reasonably lightweigt and good 18 inch rims to recommend? Also can it clear BBK?
jonleeck;1097301 said:
Jason 8822..... look at the above comment.
Agree with you on everything here except the look. 20in looks way much better than 18in.
The definition of reasonable here means close 2 eyes can accept lar...
Go pml or bmw ag website to download the catalogue and check out the sized.
18in after mkt ? I think you better stick to stock rims.
Some 380mm bbk might be able to squeeze into 18in wheel, but seldom do we see ppl UPGRADE F10 BBK while running on 18in wheel
Managed to cut a page for you :
245/45r18
275/40r18
Front
18x8.5 et33 or 18x8 et30
Rear
18x8 et30 or 18x9 et44, although et44 is oe spec, but I feel et44 go into wheel arch too much.
Do yourself a favour and get at least 19". Due to the not so aggressive offset from bmw, even if you put 19", it will actually still look small.
either mod all the way or dont mod ...
19 inch is a fair balance between comfort and O so slightly better looks. But if u gonna do 19s then only oem rims will look decent. After mkt ones will look tiny and u will regret why u didn't just wack on 20s.
Anyone knows if under settings, we can modify or activate lighting options for interior or external lighting via software mods?
Does anybody have experience with racechip? Care to share??
I just ordered LED interior lightings for my ride..
Looking fwd to replacing the stock bulbs with brighter and sharper LED ones..
:shakemyb::shakemyb::shakemyb::shakemyb:
Got check led is can bus compatible ?
