franklkk
Re: What's more???? Frustration. - Radiator Fan Kaput
Hi, your ride & my ride can become brothers man.
You are right. I hate car to be place in the workshop for 2 to 3 days. It's really inconvenience me. By the way, how much did you replace your shock absorbers??
delrosa81;702519 said:All these wear and tear are normal for this car. My car is rching 4 yrs old this coming dec.
I have replaced the following items:-
Oct 2010: Changed New Gearbox, under warranty
Mar 2011: Changed a new set of shock absorbers
Aug 2011: Air Con fan coil leaking, changed a new fan coil
Sep 2011: :Leaking Vanos sensor x 2 and engine oil filter housing leaking. Changed all the 3 oil seals, change dunno wat pulley and changed the washer fluid water pump due to leaking also.
Today Nov 2011: Now car in work shop to rectify the following, leaking oil sump gasket, leaking engine oil pump, leaking rear axle box or rear differential, leaking power steering piping, changing new whole set of radiator hoses top and bottom and still awaiting for more bad news.
From forums and friends, I have known these common wear and tear issues so my expectation of the car's reliability is still within tolerable limits. But the thing is due to the complexity of accessing some of these problem areas, car will not be ready within a day, thats what pisses me off. At least 2 to 3 days to properly rectify all the problems.
As such, I look forward to "problem free" motoring for the next 2 to 3 yrs after all the rectifications.
Don be too fustrated over all these issues, get it replaced and done up properly and the car should serve you nicely for quite awhile.
Happy Motoring!
