katoomee said::roll: :roll:
think the wiring problem. cant control up and down of windows
Wayansurfer said:katoomee said::roll: :roll:
Hi Katomee,
It would be best if you could eloborate more. Normally if a ure unable to wind up ur windows and all, check the fuse box.Change the fuses if u need to. The second step is to change the switch first. Werk on the possible cheapest remedy. getting the switches are easy....all u need to do is to hit Propel. I assume ur ride is an E36?
fyi, the switches will cost you $10.
Gd Luck
gwumpkus said:right on bro.. and if the cheap solutions fail...well..ur motor may be busted... let me know if it is..i've got some prelim checks/remedies BEFORE u run out and buy a new one....(which will cost u $100 or so from the yard..)
Wayansurfer said:Hi Katomee,
Gd Luck
katoomee said:thks, i had ask around and no shop willing to check. can advise me wher to check and replace it? thks again
Wayansurfer said:Meaning, the shops not willing to check your fuse box??
maybe you can pop at this Friday's meet up for the E36 family...see thread in Classics.
Then from there, we could look see look see for you.![]()
