WTS:Used e60 Msport Suspension and brakes
Re: WTS:Used e60 Msport Suspension and brakes
MW;710787 said:
Just to query, although the suspension and brakes were taken out from an E60 M-Sport, are these parts M-Sport parts or just stock parts?
As far as I can remember, only 530 and above have M-Sport parts...
If your parts are really M-Sport parts, then those who want stiffer suspension and better brakes can consider...
it is is msport suspension bro,thats what bmw confirmed with me.who ever interested i can pm them the part number so you can verify it.tq
For M sport suspension there is also front and rear bars which are slightly thicker and stiffer than standard suspension along with bigger bushes this is a standard part of Msport suspension . Most of the rubber components will need to be replaced with new ones anyway.
If you mentioning the sway bar,yes the size is 25.5mm and rear 16mm it is big.
Therefore you are selling the front and rear shocks+springs with or without the sway bars (AKA ARB)?
Will the shocks and spring fit and be suitable for 523?
Thanks.
Can these 525 shocks fit and is suitable for 523? I want to use H&R springs on the Msport shocks. But not sure if its suitable for for 523. Maybe it will be stiffer, but rider height should not be affected, since the spring height determines the ride height.
Thanks
Thanks
it should fit bro as my friend is using msport suspension on his 523 but the original msport spring is good enough,h&r is too stiff and bumpy on msport suspension.
Thanks.
The price is COmplete with the original msport spring and msport suspension bro.I have the original sway bar front and rear,if you give me a good offer i can let it go.tq
Jay (avinash), I am having difficulty finding you because you changed all your phone numbers and went MIA. Can you please let me know if you are still interested in the exhaust? If not at least let me know instead of disappearing totally.
avinash;748336 said:
bump.................
Hi there,
Please clarify whether your Msport suspension is 60,000 km or 6,000 km in mileage.
Thanks.
BlackAss;748454 said:
Hi there,
Thanks.
60,000 bro
kubetlinkcom
