Anti-roll bar for f10 535i
Arowana76
Have been driving my car for a month now and my first BMW, but Find the car has a lot of roll will doing normal cornering... Unless switch to sport mode with enhance chassis, but can't be driving with sport mode all the time right....
Any feedback on after market anti roll bar to replace existing stock?
Any recommendations, where to get n what's the damage?
If to replace, change the rear will do?
Thanks in advance.
Re: Anti-roll bar for f10 535i
Eh, I drove sports mode most of the time...
Have not heard about ARB for F10 or maybe I missed it...
AC323 will recommend you coilover...
Thanks in advance.
what tyres are you using?
If there is dynamic drive, LL drive in sports all the time lor.
Under the sports mode, you can select it for the chassis and not the transmission so that might partially address your concern. If want to change spring let me know so we can do a small group buy :)
You can buy direct from getBMWparts.com and ship via VPOST to Singapore and get any local workshop to install for you. Please get them to verify with your VIN no to ensure full compatibility and you will be the first F10 in Singapore with such feature and you can post your experience in BMW-sg to all our brothers.
use citibank borderlinx ... vpost sucks
Since it is only for ///M5, how could it be verified via VIN no.?
If that portal can ship direct, ship direct via Fedex. VPOST is hopeless.
getbmwparts used to ship internationally
then kena whacked left/right/center by overseas dealer ... now they only ship USA address
You got the m5 front anti sway bar? What's the damage??? Good handling after that?
Its definately better than the stock ones. I've got AC Schinizter springs as well which as installed more than 1 year ago. price about $600 if i rem correctly.....worth the mod.
Anyone knows whats the difference in thickness between stock f10 and M5 sway bars?
Also, Ducatti, $600 for the sway bar or the ACS Springs? if for the springs, how much is J4C charging for the sway bars?
M5port;988777 said:
RealOEM...
S$600 is for the M5 Anti roll bar. AC Schnizter spring I cant rem price but maybe around 1k or so
M5port;988777 said:
