Anti-roll bar for f10 535i
Re: Anti-roll bar for f10 535i
u sure replacing rear ARB is as simple as front like remove old and install new?
direct plug&play
Jason8822;1019029 said:
Ya lor
Wonder why those after market parts maunfacturers still not come up with their antidote
Maybe cos they worry that FC will increase after installing their parts and owners KPKB
direct plug&play
Hehe, not sure
But it looks quite ok, not too complex compared to E60
Jason8822;1019023 said:
Had a chance to peep under my car when at Doc Rod's ws earlier and took this pic
F10 rear anti roll bar pathetically small
Maybe civic have a thicker bar below
Yes. The rear one is really thin. So much different than the front.
U installed the M5 front ARB as well?
thought rear wheel drive we should upgrade rear ARB instead of just front???
* i could be wrong......
No I did not.
Ya, I'm looking for a rear ARB instead.
mw already explained that why few f10 owner look to upgrade rear arb because
1. m5 rear arb could not fit normal f10
2. msport arb only 1mm thicker than stock ... what for
Happy can already.....
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
Tmr i form singapore first F10 REAR ARB out of this ...
Wonder will it increase FC or not ....
Good idea. Just cable tie to existing ARB. More than 1mm increase! If cable tie can hold down train tracks, sure no problem on BMW!
FC sure increase because keep lupping corner. Tire wear also increase.
Bros, I want to check if I am changing my F10 523i front anti roll bar to M5, do I need to change the sway link which connects to the anti roll bar?
Please advise thanks
MW;1013996 said:
Ok today just installed M5 ARB..
Haven't tested the cornering yet at "higher" speeds but initial feel is... its feels like stock on straight roads, not hard at all.
Tested on various humps...ok, not hard at all, feels like normal.
Did a few cornerings at "lower" speeds of 50-60km/hr...dunno whether its psychological or not but I tend to think its feels more planted than stock.
This evening will try higher speed cornering and see whether good or not.
Anyway, its a cheap mod over stock ARB cos sibeh "thin"..
Borrowing from f10.5post..the pic of the M5 ARB is ...
26mm thick.... stock is about 20mm
Those on M-Sport suspension your ARB thickness is about 23mm..so its a 3mm increase.
I also ordered for two other F10 forummers...both 535i and on M-Sport suspension. They will install tomorrow and I hope they can feedback as well...
Or you can buy my like new bilstein b6 shocks which would remove a lot of body roll and stay flat when cornering. But it stiffens up the ride a bit.
comes as a set
