oneHeadlight
Re: anyone upgraded ICE on E90?
Cutting the door may actually reduce rattles. Look at iceman pics for good reference. I am not familiar with e90 but if the stock location of speakers are same as e46, then i suggest you cut the door, also resulting in better sound.
I still highly encourage you to get a separate amp for your sub, because a mono amp is the most efficient use of power for subs. Subs draw power like nothing...
The common misconception about subs is that it will result in big booming like a ah beng car. Its NOT necessary so. Bigger subs allow you to play certain lower frequencies, it doesnt mean it plays louder !!
You should bridge your 4ch into 2 for your front components, and get a mono amp for your sub.
Your 4ch amp will struggle to play the comps and sub effectively.
Motofish said:Cut the door, no. I am also alergic to rattles. I am not sure if HD will fit the exisiting space, if its too big, I will select for model/brands. I will also follow good advise from the forum - stay with the car while they do the install even if it mean taking one day leave. I want to know what the guys are doing with my car.
Amp selection, at this point in time, I was recommend Blaunpunkt 4X75 amp, probably becos he knew I am no audiophile. Will consider mono-amp (budget and space). Music clarity and good vocal are more important to me than BIG bass.
