Daniel Tan;443151 said:hi. went down last weekday to view (diagram) at the intake for my 1er, the intake is of different design compare to the 3er. on the surface look almost the same but inside the box it use open pod like gurppe m. unlike the 3er which the normal drop it type. when i ask how much is the replacement cost for the open pot, they dont have pricing yet.
niteblu;443361 said:If you look at the air filter (in the stock airbox)
For the FL e46 318 - (Similar engine to the current e90 320)
It's not a box panel filter.
It's sort of cone shaped as well, similar to the k&n/gruppe-m cones.
dsdfan;442787 said:I'm keen to know if the Performance Intake offers significant advantages compared to stock intake with a K&N filter already installed.
Engineering details are beyond me, so I don't bother with them. But because we can't actually try out how well a Performance Intake actually performs in a real car, technical differences are all we have to go by.
1. The front part of the Performance system: the intake channel, has a deeper shape than the narrower stock version, which I assume allows air to flow in more freely. The Carbon Fibre top is merely decorative. The intake channel itself is plastic, like the stock version
2. This intake channel also fits directly to the airbox, whereas the stock version connects to the air box via rubber hosing. Perhaps the accordion-like surface of the rubber hosing might disrupt air flow, so the direct connection of the Performance Intake probably allows smoother passage of air.
3. The Performance Intake also features an "air guide", which is a second inlet taking in air via an opening at the top of the hood. I popped my hood to check and the inlet is really tiny; can't be much more than 3 cm2. So why is it there? Obviously, it cannot let in huge volumes of air, so it must have a different function. My guess is the "air guide" is strategically positioned at the rear end of the intake to allow air (somehow) to flow more freely inward from the main front inlets. Perhaps someone with knowledge of convection in air ducts and vents could shed light?
Other than these enhancements, the stock air box which houses the filter is re-used, except that a new lid is provided which allows the air box to connect directly to the new air guide and new intake channel.
Probably, BMW has done careful research and won't sell all these parts at such a high price if there is no worthwhile increase in throttle response & power. But has anyone tried in reality?
jonsuta;443476 said:I've just came back from PML for dropping my car off for service. While I was there, I've dropped by the parts department for their recent promotional sales on these Performance Accessories (ends on 21st June 2009). For the Performance Intake, the promotional price is S$1,475.53 (inclusive of parts, installation, and GST). (Originally, S$2,000+)
As per described by the parts department personnel, the package includes all the things that bro dsdfan has describe, plus change of air filter from the stock paper air filter to some form of special air filter (trying to ask for more details, but the personnel cannot describe/reveal it).
Overall, 25% more air will be intake, compare with the stock setup, as per described, which will also create a deeper engine sound, especially during higher rpm.
clar;443611 said:The last sentence also mentioned that the gain is 20bhp!!! This is exciting stuff!
jonsuta;443476 said:Overall, 25% more air will be intake, compare with the stock setup, as per described, which will also create a deeper engine sound, especially during higher rpm.
