BMW Portable Naviagation system
Re: BMW Portable Naviagation system
send in the car yesterday 8:00am and collect the car today 12:00pm.
the SA said in addition to re-program the audio control, actually they need to replace a few parts in the HU. that's why they need at least 1 to 1.5 days to complete the job. now sui sui instruction with turn left, turn right and no more ... eeeeee eeeee eeee :)
Can anyone tell me what is the latest version for Sing/Mal map on the BMW portable nagivation system? Mine is NT v 3.00. And how to update map??
Also, how to synchronise sms messages between mobile phone and BMW portable nagivation system? Problem: sms in my phone deleted, but still in the nagivation system
Thanks
wt,
Can your phone messages synchronice with your garmin set? The oid messages still remain in the Garmin set although it has been removed on the phone.
What is your map version.
Audio086;445944 said:
wt,
What model handphone you using? Can support SMS?
And, I accidentally installed a Nuvi 760 map and now everytime the gps is powered on, there is an error message ünable to unlock maps"comes on. Anyone can tell me how to uninstall this incorrect version map?
hI,
i am using Sony K750i. Can send and receive message in GPS. BUt, the message cannot sychronise. ALso updated the latest GPS software, still cannot work.
Bro, Is the map saved on memory stick ?
If yes just thrashed it & replace with any maps
fr malsing or Malaysia & Singapore Free GPS Map Project • View forum - General GPS Forum
Otherwise u can do a hard reset, to return to default settings
on the gps unit. There's a pin size button located on the base of the unit.
DIfferent models different location.
Locate it & use a pen tip to depress it & hold a few secs.
bro, message can sync but it takes a long time................tired it once
I am not patient enuff to wait, plug sync with hp twice & drive off.
:( I tried reverting back to defaut setting but it didnt work. Its not in the memory card. When installing, I was asked to remove the memory card. Now it has overwritten the original Garmin map. No more postal code search!
Can anyone help?
as what you said, i suspect revert to default setting only reverting the setting but the "original program" pre-loaded in the garmin has been overwritten by your own upgrade.
possibilities
a. download from garmin or google online the original program for this model
b. look for garmin store/support locally (funan or sim lim?) to reflash this model/unit to original program or newer program with more functions
c. get help from PML (hopefully they don't charge an arm and a leg) -> act blur la ... said don't what happen you tried reboot few times and then this unit go haywire and now no postal code search !!! .... kekeke
possibilities
PML ppl got no brains. I think I know more abt the Garmin unit than them! I took back the Garmin after 4 days cos they can't solve it and am liaising with Garmin Taiwan on my own. This level of technical expertise also can be SA..... Heard that the software for this nuvi 710 is unique to BMW.
haha ... never under-estimate PML stupidity
I was wrong and made such a BIG mistake...
I just cannot get down to their level to communicate effectively with them! And yes, I definitely underestimated them for having such astonishing level of stupidity...
washington678;450364 said:
This is an interesting discussion.. thank you for sharing.
pret auto
I sent an email to Garmin Taiwan, and they say I need to send the unit back to them for reprogramming and pay usd35 for fright charges!
Bunch of useless at PML still don't have a clue what the issue is!
Anyone has got any idea how to get updated Sing/Mal map for 710? I checked some shops and it costs $249 for SE Asia map! But I do not know if it is compatible with our nuvi 710...
For the lay person, goto: malfreemaps.com
After download the lastest for Garmin Nuvi, follow some instructions and just copy their "map" file into the correct garmin directory. Remeber to save a copy of your existing file should u need to replace it.
Or goto: malsingmaps.com
They also have a recent release given free but u need to do some more work to get this going. Both are suppose to be compatible to all Nuvi's even I had updated my BMW nuvi on the first day I had it..
or read somewhere that some members go to Eastgear (a parallel importert) to buy a working copy of malsingmaps - check out past msgs.. something like $40 including a sc card.. - I don't use this path, hor.. check properly or call them to confirm. I use both malfree and malsing maps.. directly Very easy if u know how to..
Paying .$249 is "crazy" can buy a new hardware nowadays!
What sort of work has to be done to the free update before it can be used on BMW Garmin?
pg88comim
