zapp;1109959 said:Hi. Anyone had installed car camera using the cigar outlet below the glove box on front passenger side? Is the 12vdc power always on? Or cut off after engine off?
[video=youtube;LfmAhDq7lxc]http://www.youtube.com/watch?v=LfmAhDq7lxc[/video]
I goggled and found this.
mercuryz;1110946 said:Hi zz
For the constant recording I am using Blackvue 550 front and back but because I have the Lukas installed next to it I have to say the blackvue runs really hot compared to the Lukas. Because of this I would not recommend Blackvue, instead try ITB100HD (which I heard works great even when parked under Sun) or the Lukas front and rear camera.
The power is connected via a Powermagic Pro wired to the cars electrics, there is a timeout set by my installer to shut down the camera after 6 hours or if the battery runs below a certain threshold. To be honest 24 hour recording is not practical as the battery will drain out pretty quick, also when you park under the sun leaving the camera on so long will just fry it.
zz1248;1110961 said:Thanks a lot mercury. The website shows DR550 is obsoleted now, so was considering DR530 with T-power plus for parking mode recording as it claims can last 10 hours, not really keen to use car battery as worry about void the warranty. Now looks like need to consider what you recommended due to the temperature issue.
mercuryz;1111009 said:If you're concerned about warranty consider the PML $800 BMW car camera, its costly but won't impact your warranty.
