Car lost power
Re: Car lost power
paiseh revive this thread again...cause i suspect it might be the same problem (valvetronic, fuel pump or ignition coil)...
my car when moving off also suddenly lost of power...
case in point: previously i tried to reverse on an up slope or move off from one....suddenly power cut...cannot move...machiam engine dead...then i need to switch off engine then start again...sibei jialat...
same problem anot?
Re: Car lost power
Time to change car
Re: Car lost power
wt_know;618275 said:
hahaha
is this is the new tagline to replace ... comes with sprintbooster? ... opps that's terry !
Errr nope, the sprint booster tagline belongs to Toto?
Re: Car lost power
same problem anot?
From personal experience, prelude to valvetronic failure. Better got it checked out. Btw, what model are you driving?
Re: Car lost power
actually have been happening for months...everytime try to show the workshop, it happens perfectly fine...
e90 pre-fl 320i :whatthe:
Re: Car lost power
XXX;580066 said:
did you install tuning device like Unichip etc?
Will Unichip caused that??????
hitmee;618581 said:
Why Pcc? U can always look for milk15.
Look for me???? u wan Akm for me?????
Re: Car lost power
Not sure if I am facing the same issue. Occasionally (by which I mean about 25% of the time), I feel the car acting up strange. The engine note just sounded different when going though the revs, and the car basically takes a longer time to accelerate ie definately feels more sluggish as though its trying to pick up speed at a higher gear. Then magically, when starting off at the next traffic light, all goes fine again.
What is the causes of such symptoms? My mileage is about 80k now. Problems with the sensors or vacumn tubes turning hard and causing pressure loss/leaks etc? Or could it be with the fuel pump? However, there are no error codes thrown up. Mine's a 325i.
Re: Car lost power
pengful;580062 said:
1-2 seconds kinda feeling. The feeling is like you step on it but car just would not move, then it slowly picks up again.
step the paddle faster instead of gradually. try if this help
Re: Car lost power
hey bro, I'm not sure if we are facing the same problem but my 325i does feel sluggish at times as well. Went for servicing in pml just last week but no problem detected though.
Re: Car lost power
I do encountered such a problem occasionally, either when making U-turn or when try to move off after traffic light.
Went down to PML few times, and told them the problem, they tested drive but smooth sailing.
I believed it should be a common problem but they just shooted back unless it happen during their test drive, else they couldn.t detect it.
My ride still under warrranty, it a mid 09 FL 320i. Maybe they r trying to delay till warranty over so that they don't need to replace FOC?
Re: Car lost power
Let me revive this old thread
Recently, the same problem happen to me. when slowing car down and upon acceleration, the car experience no power for 3-5seconds. Power kicks back only after feathering with the thorttle.
Really wonder what could be the problem. Mileage of my ride 80k. Could this be a serious problem? Also, I see many times in this thread with regards to valvetronic motor. Any bros can advise how much does it cost to replace?
Thanks
shbetlegal
