Happy New Year Everyone!
Cheers,
Best Regards,
Revol Carz Garage Admin Team
@ Ang Mo Kio
Tel: 6555 1171
Is your Car due for Engine oil change?
Regular interval Car Servicing is crucial to maintain your vehicle's optimal performance, extend its lifespan, and ensure safety.
At Revol Carz Garage, Our experienced technicians provide expert care, optimizing your car's performance and reliability.
Revol Carz Garage Team specializes in BMW repair and is equipped with the knowledge and tools to identify and rectify car issue efficiently.
Do feel free to drop by Revol Carz Garage at 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171 or whatsapp us at https://api.whatsapp.com/send?phone=6593222338.
You may also SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
Mr. Loh's BMW 640i requires an Engine oil change, and he has chosen to visit RevoL Carz Garage for the service.
The Air Filter is visibly dirty and requires replacement.
The Rear Brake Pad and Rotor exhibit signs of wear and are in need of replacement.
The Rear Brake Rotor and Pad replacement is executed with minimal downtime.
Every car service includes a complimentary car wash and vacuuming for your added convenience and a sparkling clean finish.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Changing Brake Pads and rRotors is a crucial aspect of car maintenance. Over time, Brake Pads wear down, and Rotors may develop grooves. Timely replacement enhances braking efficiency, prevents damage to other braking components, and ensures your car's safety on the road.
Is your car due for Servicing? Don't overlook these vital tasks – schedule maintenance today with Revol Carz Garage for a smooth and safe driving experience
The BMW 216D Owner is due for engine oil change and visited Revol Carz Garage for Assistance.
During the Car Servicing process, our BMW Specialist carefully elevates the vehicle, meticulously inspecting for any potential major issues beyond the routine checks.
The Air Filter has been replaced with a genuine BMW Air Filter.
The worn Rear Brake Pads and Rotors have been swapped out for a fresh, brand-new set.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you suspect an issue with the Door Lock on your Car, several symptoms might indicate a problem. Here are some common symptoms of a potentially faulty door lock:
1. Difficulty in Locking or Unlocking: If you find it challenging to lock or unlock the door using the key fob, physical key, or the interior door lock switch, it could be a sign of a problem with the door lock mechanism.
2. Unusual Noises: Strange noises, such as grinding or clicking sounds, when operating the door lock may suggest issues with internal components or the actuator.
3. Inconsistent Locking: The door lock may not consistently engage or disengage, leading to unpredictable behavior when trying to secure or access the vehicle.
4. Power Door Locks Malfunction: If your BMW is equipped with power door locks, malfunctions can manifest as erratic behavior, including doors not locking or unlocking as intended.
The owner of the BMW 760i noticed an unusual noise when locking the car and sought assistance from Revol Carz Garage.
Our BMW Specialist promptly identified the problem and efficiently replaced the Rear Door Lock.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Are you experiencing persistent coolant warnings despite a full reservoir? A likely culprit is a malfunctioning spare tank sensor.
This component may inaccurately signal low coolant levels, triggering unnecessary alerts.
Consult Revol Carz Garage for a quick diagnosis and replacement of the faulty sensor to ensure accurate monitoring and peace of mind.
The BMW 520i owner faced ongoing coolant warnings despite a full reservoir and sought assistance from Revol Carz Garage.
Our BMW Specialist promptly identified a faulty Spare Tank issue and replaced it immediately, ensuring minimal downtime for the vehicle.
Replacing the Spare Tank Cap as a set guarantees zero coolant pressure loss.
Every car servicing session includes a complimentary car wash and vacuum service.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you notice any of these following signs, you might need to send in to a professional workshop to check on the Window Regulator.
Slow or jerky window movement
Unusual noises (grinding, clicking)
Window slipping or tilting
Inability to stay open or closed
The BMW 325i Owner sought assistance at Revol Carz Garage as they were unable to wind down their Window.
Our BMW Specialist swiftly identified the issue and promptly carried out the necessary repairs.
The Window Regulator is replaced with minimal downtime.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you're detecting a distinct burning odor reminiscent of Engine oil, it could be indicative of a potential issue which is often associated with a Valve Cover leak.
A malfunctioning Valve Cover is allowing Engine oil to leak, resulting in a noticeable burning smell. Swift action is essential to prevent further complications.
Visit Revol Carz Garage to inspect and replace the faulty Valve Cover, ensuring a clean engine and eliminating the source of the unpleasant odor.
The BMW 730i owner is troubled by a persistent and noticeable engine oil burning smell, prompting a visit to Revol Carz Garage for professional assistance.
Our BMW Specialist promptly identified a faulty Valve Cover as the culprit.
Removing the Valve Cover from the engine is a necessary step in addressing potential issues, such as leaks and ensuring proper maintenance.
The next step is replacing the faulty component. The new Valve Cover is ready and awaiting installation to restore the engine's integrity and eliminate the burning smell completely.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Please kindly be informed Revol Carz Garage will be closed from 9th February 2024 (Friday) to 14th February 2024 (Thursday)
Business will resume on 15th February 2024 (Friday)
Happy Chinese New Year 2024!
Gong Xi Fa Cai!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
A low voltage battery in your BMW can set off a chain reaction of issues, including the generation of false fault codes. The vehicle's complex electronic systems rely on stable power to function correctly.
When the battery voltage is compromised, sensors and control modules may receive inadequate power, leading to erratic behavior and miscommunications.
These fluctuations in voltage can cause the onboard computer to misinterpret signals from various components, triggering false fault codes. This domino effect can result in misleading diagnostic readings, potentially leading to unnecessary repairs or replacements.
Addressing a low voltage battery promptly not only ensures proper functioning of electronic systems but also helps in preventing the occurrence of false fault codes.
Regular battery maintenance and timely replacements are crucial for the overall health and reliability of your BMW
Registering a new battery in the BMW IBS system is a crucial step too!
The BMW 523i owner sought a second opinion at Revol Carz Garage to determine if the additional parts indicated in the fault diagnosis are necessary.
Low voltage battery can casue false fault code in the system.
Replace BMW's original battery with IBS coding for ultimate peace of mind.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you find yourself needing to replenish Coolant between regular service intervals, it signals a potential Coolant leak. It's imperative to promptly schedule a visit to the workshop to address this issue, preventing any risk of Engine overheating. Taking swift action ensures the continued optimal performance and longevity of your vehicle
The Owner of the BMW 520i received a Coolant low alert and sought assistance by visiting Revol Carz Garage.
Our BMW Specialist promptly lifted the car for inspection.
Our BMW Specialist, with finely honed observational skills, promptly identified the Coolant leakage issue.
The new Hoses have been replaced, resolving the Coolant leakage issue entirely.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Are you hearing a light rubbing or knocking sound while crossing humps or uneven roads?
If your BMW car is experiencing annoying knocking sounds, it's crucial to address the issue promptly. Common symptoms include:
1. Knocking Sounds: Unusual knocking or tapping noises, especially during acceleration or braking.
2. Vibrations: Vibrations accompanying the knocking sounds.
Visit Revol Carz Garage for swift and expert solutions. Our skilled Technicians specialize in BMW diagnostics, ensuring a smooth and silent ride.
The BMW 528i owner, referred by a friend, sought assistance at Revol Carz Garage for a troublesome knocking sound.
The car is promptly lifted for a thorough inspection.
The main culprit has been identified – a worn Front Shock Absorber.
Enjoy a complimentary car wash and vacuum with every car servicing.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
As your vehicle crosses the 100,000 km mark, it's crucial to consider changing the Fan Belt to prevent unexpected issues.
Over time, wear and tear on the Belt can lead to deterioration, increasing the risk of it snapping.
A snapped Fan Belt not only disrupts engine cooling but can also cause extensive damage to other components. By proactively replacing the Fan Belt once it crosses the 100,000 km milestone, you ensure continued reliability and prevent inconvenient breakdowns.
Invest in the longevity of your vehicle and schedule a timely Fan Belt replacement for a smoother and worry-free driving experience.
The owner of the BMW 520i chose Revol Carz Garage for Routine Servicing.
The BMW 520i underwent thorough inspection, meticulously conducted by our BMW Specialist after being hoisted up.
As your vehicle surpasses 100,000 km, a meticulous inspection of the Fan Belt becomes imperative. Any discernible cracked lines on the Fan Belt signal a need for prompt replacement.
Ensure optimal performance by replacing the Fan Belt Tensioner as a set, enhancing the overall efficiency of your vehicle.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Are you experiencing signs of Engine overheating?
When signs of Engine overheating appear, it is advisable not to drive further to prevent potential damage to the Engine.
Recognizing symptoms of a faulty Coolant Pump in a BMW 318i, such as Engine overheating, coolant leaks, unusual noises (whining or grinding), coolant puddles under the car, and potential dashboard warning lights, is crucial.
Prompt inspection and replacement by a qualified workshop like Revol Carz Garage are recommended to prevent Engine damage and ensure proper Cooling system function.
The owner of the BMW 318i visited Revol Carz Garage due to an Engine overheating issue.
Our BMW Specialist swiftly identified and confirmed the issue.
Due to high mileage, a worn Coolant Pump is often a culprit.
When dealing with high mileage, replacing the Thermostat along with the Water Pump ensures peace of mind while driving.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Replacing the Auto Transmission Fluid in a BMW is recommended at higher mileage for several benefits.
It helps maintain smooth gear shifting, prolongs the lifespan of the transmission, prevents overheating, and ensures optimal performance.
Regular Fluid replacement at around 60k mileage is a proactive measure to enhance overall driving experience and prevent potential Transmission issues.
The BMW 540i owner visited Revol Carz Garage for Auto Transmission Fluid replacement.
The car is lifted in preparation for the Auto Transmission Fluid replacement.
Revealing the BMW Mechatronic – Gear Control Unit.
To ensure optimal Gearbox performance, it is recommended to replace the BMW Auto Transmission Oil Pan simultaneously.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Selecting a professional workshop like Revol Carz Garage for your BMW Battery replacement with IBS coding is essential for precise compatibility, preventing fault codes, preserving Battery life, and ensuring overall safety and performance.
It's a proactive measure to maintain your vehicle's integrity and enjoy a worry-free driving experience.
The owner of the BMW 216D visited Revol Carz Garage for routine Servicing.
It is crucial to perform IBS coding after a Battery replacement to ensure proper integration and optimal performance of the vehicle's Intelligent Battery Sensor (IBS) system.
Replacing a clogged Air Filter is essential to ensure optimal engine airflow.
A clean AC filter ensures better air quality inside the vehicle by trapping dust, pollen, and other airborne particles.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you notice any of the following symptoms, it's advisable to have the Thermostat inspected and replaced by a qualified mechanic to ensure proper Engine temperature regulation and prevent potential damage.
Identifying a faulty Thermostat in your BMW involves observing several signs:
1. Engine Overheating: If your Engine consistently overheats, it could be a sign that the Thermostat is stuck in the closed position, restricting coolant flow.
2. Low Heater Output: A Thermostat stuck in the open position can cause the Engine to run cooler than optimal, resulting in reduced heater output inside the vehicle.
3. Fluctuating Temperature Gauge: A malfunctioning Thermostat may cause the temperature gauge on the dashboard to fluctuate unexpectedly, indicating inconsistent Engine temperatures.
4. Poor Fuel Efficiency: A Thermostat stuck in the open position can lead to reduced Engine operating temperatures, resulting in poor fuel efficiency.
5. Coolant Leaks: Check for Coolant leaks around the Thermostat Housing or Gasket, which can occur with a damaged Thermostat.
6. Check Engine Light: A faulty Thermostat can trigger the check Engine light on the dashboard, signaling potential issues with the Engine temperature.
The BMW 530i owner noticed higher Engine temperatures and promptly sought assistance at Revol Carz Garage for a thorough inspection and resolution.
There is visible Coolant leakages.
Our BMW Specialists are experienced and professional.
The new Thermostat is replaced, providing peace of mind for optimal engine temperature regulation.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Selamat Hari Raya!
For our Muslim friends, wishing you a Hari Raya filled with warmth, love, and delightful moments. Celebrate this day with joy and happiness.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Are you experiencing engine stumbling, power loss, rough idle, vibrations, decreased fuel efficiency, or a lit check engine light in your BMW?
These signs may indicate a misfiring issue and in most likley cases is due to a worn Ignition coils.
BMW Owners should strongly consider replacing their Ignition coils along with spark plugs once mileage mark crosses 120km to prevent misfiring.
This proactive approach ensures optimal engine performance, reduces the risk of misfires, and contributes to the overall longevity and efficiency of the ignition system.
The BMW 318i Owner is experiencing heavy engine stumbling and vibrations!
A rapid scan conducted by our BMW Specialist unveiled the precise fault code, allowing for accurate and efficient diagnosis.
The Ignition coils have been swiftly replaced.
In case you're unaware, a 4-cylinder engine is equipped with 4 Spark plugs, while a 3-cylinder engine has 3 spark plugs.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you're experiencing squeaking or grinding noises while braking, it's a clear sign that your Brake Pads and Rotors are due for replacement.
Keeping up with a regular Preventive Maintenance Schedule at Revol Carz Garage is the key to keeping your BMW delivering optimal performance and passion you love.
The owner of a BMW 116i visited Revol Carz Garage for a Brake Rotor and Pad replacement
The replacement is swiftly performed
The replacement involves both new sets of Brake Discs and Pads
Experience peace of mind with our Brake Rotor and Pad installation services
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you find yourself needing to replenish Coolant between regular service intervals, it signals a potential Coolant leak. It's imperative to promptly schedule a visit to the workshop to address this issue, preventing any risk of Engine overheating. Taking swift action ensures the continued optimal performance and longevity of your vehicle.
The BMW X1 owner sought assistance at Revol Carz Garage due to a Coolant low issue.
The car is hoisted up for a thorough check, ensuring a comprehensive inspection of all critical components.
The culprit identified: a worn Oil Filter Housing.
Replacement in progress.
After the repair, behold a beautifully cleaned Engine bay.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
