Revol Carz Garage: Expertise in Car Servicing for Safe and Confident Driving!
If you're noticing oil leaking from the Oil Filter Housing, several symptoms may indicate this issue. Look for oil puddles under your car where you park, consistently low oil levels, a burning oil smell, and a warning light on the dashboard. The engine might perform poorly due to low oil levels, with symptoms like rough idling, decreased performance, or unusual noises.
Regularly check your oil levels, inspect for visible leaks, and monitor dashboard warnings. If you notice any of these symptoms, it's best to have a professional mechanic inspect and repair the issue. Revol Carz Garage offers expert diagnostics and repair services to address oil leaks and ensure your engine remains in good condition.
Do feel free to drop by Revol Carz Garage at 10, Ang Mo Kio Industrial Park 2A # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171 or whatsapp us at https://api.whatsapp.com/send?phone=6593222338.
You may also SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
BMW X1 Owner sought assistance at Revol Carz Garage upon noticing oil leaking under the vehicle.
Our BMW Specialist meticulously inspected the vehicle to thoroughly identify the main cause of the oil leak.
Discovered the oil leak coming from the Oil Filter Housing.
A new Oil Filter Housing installed to ensure the problem is fully addressed and prevent future leaks.
Cheers,
Best Regards,
Revol Carz Garage Admin Team
@ Ang Mo Kio
Tel: 6555 1171
If you're experiencing increased vibrations throughout the vehicle, noticeable engine movement during gear changes or acceleration, clunking or banging noises, louder engine sounds inside the cabin, potential misalignment issues affecting other components, transmission problems like difficulty shifting gears or leaks, and reduced performance and fuel efficiency due to engine instability, these could all indicate worn engine mounts.
Regular inspections and maintenance, including checking and replacing worn Engine Mounts as needed, are crucial for optimal performance, longevity, and safety. Consulting a professional mechanic for thorough inspections and timely replacements can prevent bigger issues and keep your vehicle running smoothly.
The BMW 218i Owner noticed vibrations, which prompted them to seek assistance at Revol Carz Garage.
The Mechanics at Revol Carz Garage inspected the vibration issues and other critical components for the vehicle's overall health and performance.
Our BMW Specialist identified sunken, worn Engine Mounts as the cause of the issue.
Replacing the worn Mounts restored the vehicle's smooth operation and ensured optimal performance and safety.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
May this Festival of Lights bring brightness and joy to you and your loved ones!
Happy Deepavali, from all of us at Revol Carz Garage!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you're experiencing any of these symptoms in your BMW may point to cooling coil issues, warranting prompt inspection and repair by a qualified technician for optimal cooling performance.
• Struggles to cool properly, longer cycles
• Increased energy consumption
• Weak and uneven cooling
• Hissing, bubbling, or rattling noises
• Frequent on and off cycles
• Water leaks, high humidity
• Musty or chemical smell
The BMW 530i Owner sought assistance from Revol Carz Garage due to difficulties with cooling and uneven distribution of cool air.
After identifying the worn Cooling Coils, prepare for the installation of the new ones.
By replacing old Cooling Coils, you'll experience better efficiency, improved cooling capacity, and enhanced indoor air quality.
Change the AC Expansion Valve with the Cooling Coils for better system efficiency.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Regular car servicing is like a health checkup for your vehicle. It involves various tasks such as changing the engine oil, checking and topping up fluids, replacing filters, inspecting brakes and tires, examining the battery and electrical system, and conducting diagnostic checks. These routine maintenance tasks help ensure your car runs smoothly, efficiently, and safely.
Experience the difference with Revol Carz Garage, where excellence is our standard and your satisfaction is our priority. Trust us to keep your car in peak condition and ensure a smooth, enjoyable driving experience every time.
The BMW X2 Owner's routine servicing at Revol Carz Garage was smooth and effective, ensuring peak performance and safety.
During an engine oil change, the vehicle is prepared on a level surface and securely lifted for a thorough inspection.
During computerized diagnostics, an issue with the EVAP valve was identified.
Install the new EVAP valve securely and test for proper function.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you have topped up twice Air con gases within months with a mouldy smell from the Air con cabin. Chances are you might have a Air con Cooling Coil leakages.
Regular inspections are essential to catch these problems early. At Revol Carz Garage, we specialize in diagnosing and repairing air conditioning issues, ensuring your system functions optimally.
Contact us today for reliable service and peace of mind!
The BMW 318i Owner sought assistance at Revol Carz Garage after experiencing reduced cooling performance in the Air conditioning System.
Before installing Air conditioning Cooling Coils, the first step is to dismantle part of the dashboard. This provides proper access to the coils for a smooth installation.
Install a new Air conditioning Cooling Coil to restore optimal cooling performance and ensure a comfortable driving experience.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you’re experiencing difficulty starting your engine or it takes longer than usual to crank, it could indicate a failing Fuel Pump that isn’t delivering the necessary fuel pressure. Unexpected engine stalling can be alarming, especially if it occurs shortly after starting or while driving at low speeds. This issue may be related to inadequate fuel supply, compromising safety and control on the road.
You might also notice a loss of power during acceleration, a strong fuel smell inside the cabin, or erratic fuel gauge readings with fluctuations. Additionally, an illuminated check engine light and a whining or humming noise coming from the Fuel Tank may signal a failing fuel pump.
If you notice any of these symptoms, it’s essential to take prompt action to avoid more significant damage. At Revol Carz Garage, we specialize in diagnosing fuel pump issues and providing expert repairs to ensure your vehicle operates smoothly. Contact us for reliable service!
The Owner of a BMW 523i sought help at Revol Carz Garage after experiencing a loss of power and noticing a fuel smell.
Installing a new Fuel Pump ensures reliable fuel delivery, prevents fuel leaks, and optimizes engine performance for your vehicle.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you’re spotting coolant leaks near the Water Pump Housing, it could indicate a failing Water Pump. This issue may cause the engine to overheat, potentially leading to serious damage if not addressed promptly. Coolant leaking from the Water Pump housing often results in visible puddles under your vehicle, a drop in coolant levels, or even overheating warnings on your dashboard.
To avoid costly repairs and ensure your engine stays cool, visit Revol Carz Garage. Our expert team will diagnose the issue, repair or replace the water pump as needed, and restore your vehicle’s cooling system to optimal condition, giving you peace of mind on the road.
The BMW 216D Owner noticed elevated engine temperatures and promptly visited Revol Carz Garage for a detailed check.
Our Team efficiently lifted the car and conducted a thorough inspection to tackle the overheating issue.
Our Technicians discovered a coolant leak starting from the Water Pump Housing.
Installing a new, genuine Water Pump boosts cooling system functionality and prevents potential leaks.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you're noticing coolant puddles around the water pump area, frequent engine overheating, or low coolant levels, these issues could indicate a faulty Water Pump in your BMW. You might also hear unusual noises and see warning signs on the dashboard. Additionally, reduced heater performance may signal cooling system problems.
For a thorough diagnosis and prompt repair, visit Revol Carz Garage. Our expert Technicians will inspect the faulty Water Pump and related components to ensure your BMW’s cooling system is functioning properly. Proper maintenance of these components will help keep your vehicle performing at its best and prevent further complications.
The BMW 420i Owner needed immediate assistance at Revol Carz Garage for persistent coolant issues and frequent top-ups.
Our BMW Specialist identified the coolant loss as a leak from a worn Water Pump.
Upgrading to a new Water Pump improves cooling performance and prevents leaks.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Are you experiencing oil spots or puddles under your vehicle, oil seepage around the valve cover area, a burning smell, engine misfires, smoky exhaust, oil around the spark plugs, or potential engine overheating in your BMW X3? These symptoms could indicate a faulty or worn valve cover and gasket.
To prevent further engine damage and keep your vehicle running smoothly, it’s crucial to address these issues with prompt professional inspection and repair. For expert assistance, visit Revol Carz Garage, where our specialists will expertly service your BMW X3 and restore it to peak performance.
The BMW X3 Owner detected a burning smell and visited to Revol Carz Garage for a thorough diagnosis and expert service.
The source of the burning smell has been identified as an oil leak from the Valve Cover.
To address issues such as leaks and perform proper maintenance, removing the Valve Cover is a necessary step.
Replacing the faulty Valve Cover is the next step to restore the engine and eliminate the burning smell.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
At Revol Carz Garage, we redefine car servicing beyond a mere quick oil change.
We prioritize your peace of mind by conducting thorough checks on your vehicle, identifying and addressing potential issues before they escalate.
Our commitment to excellence means your car receives meticulous attention, ensuring not only optimal performance but also preventing future complications.
To ensure precision, we employ advanced diagnostic testing to retrieve error codes and evaluate your vehicle’s computer systems. This proactive approach allows us to identify and resolve problems early, guaranteeing optimal performance and safety on the road.
The BMW 420i Owner visited to Revol Carz Garage for essential oil change maintenance.
Our Specialist car hoisted and meticulously conducts thorough inspections, ensuring every detail receives attention.
Ensure optimal braking performance by replacing the worn Brake motor set.
Use BMW original batteries and perform complete IBS coding for a smooth and trouble-free ride.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Merry Christmas, everyone! Wishing you love, joy, and warmth this holiday season. Stay blessed and enjoy the festivities!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you're noticing puddles of coolant under your vehicle, a drop in coolant levels, or visible leaks around the Water Pump Housing, these could indeed be signs of a leaking water pump housing.
The Water Pump is a critical component of the cooling system, responsible for circulating coolant throughout the engine to maintain optimal operating temperatures. When the water pump housing experiences problems, it can lead to overheating and potential engine damage if not addressed promptly.
The Owner of a BMW 216D urgently sought assistance at Revol Carz Garage after experiencing engine overheating problems.
Immediately, our BMW Specialist conducted a meticulous and thorough inspection of the overheating issue.
After identifying the worn Water Pump Housing, we promptly replaced it with a new one.
Also replaced the Fan Belt to ensure comprehensive maintenance and optimal performance.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Happy 2025 New Year!
May this year bring you joy, good health, and exciting opportunities.
Let’s embrace new beginnings and make it an amazing year ahead!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you’re noticing the Brake warning light on your BMW dashboard, it’s crucial to address the issue promptly. Symptoms such as a soft brake pedal, unusual noises, vibrations, or decreased braking power could indicate problems like low brake fluid levels, worn brake pads, or a malfunctioning braking system component.
To ensure your safety and maintain the performance of your vehicle, contact Revol Carz Garage for a thorough inspection and professional repair. Our Expert Technicians are equipped to diagnose and resolve Braking System issues effectively, ensuring your BMW remains in top condition and provides reliable performance on the road.
Noticing a warning light on the dashboard, the BMW X5 Owner sought assistance at Revol Carz Garage.
Our BMW Specialist lifted the car for a thorough inspection of all components to ensure in good condition.
The warning light indicated the need to replace the Brake Pads and Fluid.
After identifying the worn Rear Brake Pads and Sensor, we replaced them with new ones.
Regularly changing Brake Fluid ensures optimal brake performance, prevents corrosion, and extends the lifespan of braking components.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you're noticing coolant leaking from the thermostat and experiencing engine overheating in your BMW, it’s crucial to address these issues promptly. A leak can disrupt proper coolant circulation, leading to elevated engine temperatures. You might also see coolant puddles, low coolant levels, and detect a sweet or burnt smell.
For a thorough inspection and effective repair, visit Revol Carz Garage. Our expert technicians will diagnose the leak, repair the thermostat, and ensure your BMW’s cooling system is functioning properly to prevent further overheating and maintain optimal vehicle performance.
Noticing increased engine temperatures, the BMW 420i owner sought immediate help at Revol Carz Garage for a comprehensive inspection and solution.
Identified that coolant is leaking from the thermostat and causing engine overheating.
Installing a new Thermostat boosts engine efficiency and reliability by ensuring proper coolant regulation.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you're facing a coolant low problem and notice visible coolant leaking under the vehicle, these are clear signs of a Radiator coolant leak.
When coolant levels are low, the engine may not receive sufficient cooling, leading to overheating. This can cause serious damage to engine components. Additionally, you might notice steam or smoke coming from under the hood, especially if the coolant is leaking onto hot engine parts.
Regularly checking coolant levels can prevent engine damage from overheating, and Revol Carz Garage is efficient at inspecting and fixing leaks.
The Owner of a BMW 520i sought assistance at Revol Carz Garage due to a coolant low problem.
Our BMW Specialist Team meticulously and thoroughly inspected the coolant low issue.
Our Specialist Team pinpointed the coolant low issue as being due to a leak from the Radiator.
Install original Radiators offer a perfect fit, high quality, optimal performance, durability, and warranty coverage.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you notice a burning oil smell while driving, it could be an indication of a worn Timing Cover on your engine. Over time, these components can develop leaks, allowing engine oil to seep out and come into contact with hot parts of the engine, such as the exhaust manifold. This contact creates the distinctive burning smell.
If left unaddressed, the leak could lead to further issues, like oil loss and potential damage to surrounding components.
At Revol Carz Garage, our expert technicians are ready to diagnose and address your car issue efficiently.
The BMW 216i Owner visited to Revol Carz Garage seeking assistance after noticing a concerning burning engine oil smell.
Our BMW Specialist hoisted the car and conducted a thorough inspection to identify the source of the issue.
The Timing Cover oil leak led to a noticeable burning oil smell, suggesting that the escaping oil was making contact with overheated areas of the engine.
A new Timing Cover installation is crucial for preventing oil leaks and maintaining engine performance.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
  1. Showcase Before and After Photos:
    • Highlight the transformations of cars you've worked on. Before and after shots can be really powerful in showing the quality of your service.
  2. Organize by Service Type:
    • Categorize photos by the type of service provided, like engine repairs, tire replacements, bodywork, or oil changes, so potential customers can easily find what they need.
  3. Highlight Tools and Equipment:
    • Including photos of your shop, tools, and machinery can build credibility and show that you're well-equipped to handle various repairs.
  4. Customer Testimonials with Photos:
    • If possible, include photos of happy customers with their cars. This adds a personal touch and can act as social proof of the quality of your service.
  5. Show Behind the Scenes:
    • Customers like to see how things work, so showing behind-the-scenes shots of the repair process can increase trust in your service.
  6. Quality of Work:
    • Focus on the small details of the repairs or servicing—like parts replacements or the cleanliness and precision of your work—to highlight your professionalism.
As we hop into the Year of the Wood Snake, let’s welcome it with joy, prosperity, and abundance! May this new year bring endless opportunities, good health, and happiness to you and your loved ones.
Have a great 2025 Chinese New Year celebration from all of us at Revol Carz!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
