Chipped f30 320i owners lip lai...
Re: Chipped f30 320i owners lip lai...
Wooh so serious must call people big cannon fairy .
Relax is only discussion .
Chill......
cheeeeeeeeeeeeeeeeeeers
sockster;925292 said:
Pre 2011 n20 engines there are differences. but not so now.
Anyway for the benefit of other 320i owners out there this is what ive found:
320 vs 328
Fuel injection system same
Intake manifold same
Compression ratio same
Turbo same
differences are the exhaust and gearing. Exhaust is smaller by 0.7", however the gearing is shorter for the 320.
So technically if the 320 has the same horsepower as the 328, the 320 would be faster due to the short ratios and final drive
I think there definitely are more difference to it than just this...
If not why do Kelleners provide 2 different package for the 320i and the 328i?
Just take a look at their tunes:
320i (N20B20): increase from 184 hp / 199 lb-ft to 220 hp / 238 lb-ft
328i (N20B20): increase from 245 hp / 258 lb-ft to 294 hp / 309 lb-ft
335i/135i/535i (N55B30): increase from 306hp / 295lb-ft to 367hp / 354lb-ft
Source : Kelleners F30 320d, 328i, 335i Cosmetic and Tuning Program - BMW 3-Series Forum (F30 / F32) | F30POST
If the potential are the same, then just 1 tune can liao ma...
Don't have to guess same or different. Just go check part number you will know what is same and what is different. Similarity is a lot more than we think. Bmw has that part locator portal, similar to realoem, but operated by bmw...
Hearsay most of those tuning/chipping boxes are just signal interceptor box. They take the boost pressure reading from boost pressure sensor, then tell ecu the boost is lower than it really is. I mean it has to be so because most of those boxes only tap from 1-3 sensors.
Yup, it just fakes the boost, and fuel control. Which if controlled similarly, wun 2 equal blocks provide the same (or much closer) output?
Now we are looking at 220 vs 294... Pretune, we were looking at 61hp difference between the 2. Post tune it becomes 74hp? I would only expect the 2 numbers to be closer.
No, they will not have the same power because end of the day still go through ecu...if the boost sensor reading is too high, ecu will go into limp mode. How limp is limp mode? Just unplug your boost pressure sensor and you will know liao. Drives like an old strawberry.
Anyway, 220hp vs 294hp are just claimed figures, though 220hp is on the lower side, while 294hp is on the more optimistic side. Got people dyno chipped 20i to have 50+hp gain before and after. Yet there are people who dyno chipped 28i to only 280hp nia. Then again, dyno also have error. End of the day 20i is still just 20i, it will never be a 28i.
simville;925939 said:
unleash the 328 N20 potential , mod mod mod
how i wish to turn back e clock and buy a 328 :( ... then need not be bug by mod...hahahaaa..:dance:
so now you know what you need to do for your next car :cool:
sockster;925365 said:
big cannon fairy never mod talk so much
Just go up and down the NSH often and your car will be chipped... stone chipped.
reminds me of how e60 owners wanna mod their 523 to be like 525.
thats not a bad gain tho. 220hp will be.
+1... finally someone who knows something and can contribute his knowledge relevant to this thread.
You are right.. the main difference i tink is that the boost is lower on the 320i.
what the piggyback does is up the boost by a fixed percentage. Thus the chipped 320 will gain say 30% power to 240hp and the 328 will gain 30% hp to 290hp.
This increase in boost will be allowed by the ecu becos theres some margin allowed being programmed in from the factory.
Too much increase in boost say 50% the ecu will sense something is wrong and will go into limp mode supposedly to protect the car.
Thus 320i cant simply be tuned to 290hp like the 28i engine because the ecu does not allow it(due to being sold as a 320i at lower profit), BUT the hardware(engine) is more than capable of it
it IS 1 tune. Exact same chip for 320 and 328
lets keep this to a friendly discussion thread.
328i owners if u feel u paid more for your car and have the right to take a dig and be sarcastic at 320i owners please do it elsewhere ya
To be fair I think it was friendly until you started the big cannon fairy thingy
I agree. Then now you said its the 328 owners being sarcastic
sockster;924250 said:
what tune are u using and what is your 0-100kmh timing?
This is technical discussion thread on the N20 320i please do not veer off-topic. If for some reason your threatened by the 20i feel free to stay out and not take part in this discussion
is there an need to amend your original post
just because some non 20i 's view are not in line with yours ...also no need to say they are threatened by you 20i ... not very friendly leh... they could just ignore your post totally but come in to share with you their experience on the non 20i doesnt make them sarcastic leh ....trust me you have yet to see the worst lolz
agree to disagree......
77betink
