Racebred;635037 said:for street driving, you never need a coilover. Waste money, waste resources.
if its for street driving, and if you somehow need to get a very specific ride height, you'll have to get a coilover, but a cheap one will do.
if you want to do serious tracking, then you need to get a good set of coilovers. There are many non-performance type of coilover brands out there with no proper engineering and research done. They are put out into the market because buyers have associated coilovers=performance, so many people blindly buy and blindly install. At the track, you can definitely feel the difference between a good set that cost over $10k, and a normal one that cost $1k.
In my opinion, the coilover aspect of sitting the spring does not give you any additional advantage if you do not need adjustability. In a theoratical situation where you have 1 x optimised settings, somehow, from your shock + spring set, it should perform just as well as a set of coilovers.
In any case, depending on the model of car you drive, sometimes coilovers are not possible. You buy a coilover set but actually only the front is a coilover, the rear is still separate. How many people know that?
nobkia;635426 said:actually can good coilovers ever be more comfortable than stock springs+shocks?
ac323;635432 said:Hi Nobkia,
different people will have a different level in terms of comfort......as for me, it is definitely coilover..........cant stand stock suspension...........rock the boat, like bus......(where got comfort, wanna vomit)
i find coilover very much more comfortable than stock.....................that's me not sure about other owners.............
golilok;641873 said:but lets say on uneven roads, coilovers will shake/rock more than stock suspension anot?
U can get those that doesn't.golilok;641873 said:but lets say on uneven roads, coilovers will shake/rock more than stock suspension anot?
C3P0;641875 said:U can get those that doesn't.
End of the day depends on what u want.
Vroom vroom.
Cheers.
wt_know;641880 said:on uneven road
a. big wave uneven road .... coilover solid ... up/down steady poon pi pi ... stock suspension up/down like boat
b. small wave uneven road ... coilover suffer abit as it's hard ... it jump tong tong tong (that's when my wife complain) ... stock suspension is softer hence absorb the sudden up/down better
overall, i will still go for coilover.
the above problem only experience in msia b-road and certain stretch of nsh. in singapore all expressway, coilover is good for me
having said that, coilover is not for everyone. some very sensitive on suspension. just abit harder, will complain liao. so, you decide.
I want Box Spy. Faster than 335.ac323;641877 said:so what do you want???? C3PO???
wilman2772;641889 said:Seems like you should change car!!
RX450 will be very comfy for you!!
'The Great White'
C3P0;641888 said:I want Box Spy. Faster than 335.
MTL, vroom vroom.
ac323;641891 said:how about X6M?
wilman2772;641894 said:Nah.....Lexus is most comfy & quiet!!
Can fall asleep very soundly!!
'The Great White'
CML;642993 said:Just had the V3 installed two days ago on my F10.
Enjoying every minute of the ride. Personally, I like the ride now, better than stock, especially, the rebound! More controlled.
The ride is not harsh as I thought it might be, maybe because it's set to comfy levels. Stiffer and firm but definitely not hard or harsh.
The handling is superb, really what every BMW should be. Ever since I got the F10, not as happy about the handling, prefered the E60.
Now with the V3, it brings a smile to my face every time I am in it, tackling every corner with zest and confidence of cos, it looks beautifut now with a lower ride.
My next upgrade - a new set of 19' wheels from my current 18'
CM
