C3P0;330822 said:Thanks for the good info bro. Buy you milo ice next time.
Anyway, my engine oil burns off 2L to 3L every 2500km. No leaks, all kind of gasket and pipe changes. Don't know where it goes to....(no, I did not use it to oil my own body....)
Yes, I think it is almost unheard of. No workshop can determine the problem. No valve leaking, nothing. Exhaust also ok. Everything checked. Been like that for 1.5 years.tlkchew;442740 said:2L for 2.5k? that quite a lot of oil to lose. your valve leaking? is your exhaust throwing oily soot?
C3P0;442772 said:Yes, I think it is almost unheard of. No workshop can determine the problem. No valve leaking, nothing. Exhaust also ok. Everything checked. Been like that for 1.5 years.
Lately it got worse. Every 300km, I have to top up 0.5L. So I went to temple aka R2D to pray.
Rod then suggested something to me - use a thicker oil. Touch wood and keeping my finger crossed (I am very pang dang one though I'm robot), it seems to work. More than 1,500km already and I still don't need to top up. Miracle. Rod is like sin. You know, 神. (Not horsin that sin.)
ttee;442851 said:Everything no leaking, no top overhaul, coolant no oil, exhaust no oil but is black black with some carbon, 99.9999999% this once, "05 REPAIR KIT VALVE SEAL RING", dont believe go and get three joss sticks and ask 神 :argue:
Some mechanic can change for you without pulling out the cylinder head..
blacktrek;439566 said:Bro, go to R2D and let Rod to access first. I believe he will give you a better quote.
Nedkelly;444531 said:Bro, where is R2D? Can provide the contact details? Thanks.
ttee;444601 said:Hi C3PO, ai engine oil mai?
C3P0;444650 said:Ai !! You have extra for sale? I am using 10W-60.
(0W-40 is for human beings, I'm robot that's why use thicker oil. :laughlik: )
Sorry for highjacking.
ttee;444942 said:I only have Mobil 1 Gold 0W-40 for you to oil your body. I just drain out from the engine, mileage 4k engine kekeke. mileage to 7k engine kok kok kok. ang mor say Mobil 1 Gold very good, can run number 1. I think kang kor leh.. Oil your body I think very good. ai DHL to you free.
R2D;445072 said:robot...is the situation better?
C3P0;445059 said:Thanks bro. 0W-40 too thin for my engine, that's why I need 10W-60. Serious....
Btw, DHL can send to tattoine? :woottt:
C3P0;445075 said:Yes, definitely better. Just top up 0.5L yesterday - meaning it has used up 1.5L for 2000km. Which is a significant improvement liao!
:smack: - For Rod and Roger.
- For Nadia.
jararaca;448827 said:check your PCV, make sure it is not blocked - common problem. do a google for more info.
check your compression, may be it already bakar minyak.
experiment it with a thicker oil. like Dino oil 30-50 and drive it for 3000km.
Last - do a thoro clean with auto-rx
