E90 320i PFL Coolant Temperature ? Ways to reduce ?
Re: E90 320i PFL Coolant Temperature ? Ways to reduce ?
I am here to learn n share.
On stock of n55 335, spirited runs can hit temp of 120-125 max. After oil thermostat mod temp are max 110 as fan kicks in earlier.
I have just so call upgraded to Stett oil cooler stage 2 and spirited runs will bring it max to 105-110 range max.
Have never gone track to try yet.
On coolant I just use BMW coolant and flush it every time I change plugs which is about 30,000.
Older cars should change coolant regularly too. Too low a temperature I also think it is not good as well.
Red_Bean_Bun;1076614 said:
Started with 115c on my engine when I got from my dealer - n54 engine.
- flushed the radiator and filled it with distilled water and coolant (50/50 ratio). Temp dropped slightly - moved a wee bit towards the 110c mark on my temp gauge.
- Bled the system (use bleed screw) and then added redline water wetter. It actually made it worst and went back to 115c
- Bled a bunch out (used the bleeding procedure with engine off) and re-filled with more distilled water. Gauge needle moved back closer to the 110c mark.
- Changed to GC. Gauge needle moved right on top of the 110c mark.
- Changed my oil cooler thermostat and gauge needle moved between the 100c and 110c mark.
Had engine ice on my previous Z4 (NA engine) - not much of a diff back then in terms of temp and it was costly .......
IMHO - I think the engine ice, water wetter stuff is over rated .....
easy;1076689 said:
That prob explains why my coolant is usually running high, coz my loads are low and no where to chiong :shakehea:
So gotta gun the bugger more so coolant temp will be lower?
I tried to do that, the fan came max on and coolant temp drop to 80-90'
You gun the bugger, means more air flow ... coming into the engine bay .... and flush the heat out as well ... logical ?
Stett oil cooler is solid. Can't remember but I think it has a complete thermostat bypass ?
Accordingly to WS boss, our e90 really runs hot.
Normal temp is at 100'C+ so mine that floats between 108-113'C is in normal range.
The high temp is to ensure fuel efficiency at low-normal operating loads.
When running heavy loads, the temp can come down to 90'C when full fan is on to ensure components is not over-stressed.
At heavy jam, it can go all the way up to 118'C so don't be surprised!
For preventative maintenance, do check your coolant level once for leaks and also do a coolant change per annum.
Hope this reassures all e90 bros worrying about engine / coolant temp using the secret menu.
In Singapore start stop traffic even with Stett temp will be a tick below 110.
However try it on a free expressway with very minimum traffic or say jb runs, the temp will be 100.
A very good n impressive oil cooler.
If not intending to track, or built a good mod list, a good racing thermostat is good enough.
A thermostat cost less than 200 n Stett stage 1 over 1 k plus... Depends on the long run what you like for the car.
Red bean bun - so the redline water wetter doesn't work ?? And increase the temp somemore ??
It's depends on car mate... Na or turbo etc ...
Reporting back after a coolant flush but this time with distilled water (previously WS used tap water).
Coolant temp was reduced from 113'C down to 110'C now.
Will monitor a bit more since it's been one week I did the coolant flush.
Red_Bean_Bun;1078916 said:
Did not work for me ....water wetter .....
And here is an interesting chart ......
Wow Red Bean Bro...
This table from E90 N46 Engine ?
Can control thermostat or Fan start functioning earlier ?
Or can we add "Component Protection" in the Operation Mode from 90 degree C instead of 117 degree C... (IF "COMPONENT PROTECTION" is the predefined control for the system to do things)
Sorry just guessing a round...
Staff online
jiyana13
