Vansoh;992425 said:TMD, guess it my turn to kana the legendary engine oil leak.
current mileage at 135K Km
serviced and driven for 4300km. ytd found that EO is 3/4 full from "the stick"
oil stain found on the engine area nearest to the EO cap.
Dont have passport so I guess woodlands is the furthest I can go to find a doc.
jackshen84;986645 said:May I have the details and contacts for the WS @ JB via PM.
Any map? The shop name, address, any nominal building, landmark?
I, hereby thank you forummers and this wonderful forum for such info shared.
Jackshen84
Atomic;987271 said:May I have the contacts of the WS@JB?
Thanks in advance!
userproblem;990446 said:Hi All,
Im new here, appreciate if anyone can pm me the details of francis in JB. THank u in advanced!
lkm;705327 said:I had a similar problem on my 2006 e90 - oil leak in engine bay. Mileage approx 100k. Sent to PML, and they quoted about $2k. Got a quote from one of the sponsor workshop here and was quoted $1k+ to replace "all related seals" to stop leak problem.
Not convinced, I brought car to my regular workshop in JB who specialises in BMW's. After diagnosis, mech replaced 2 o-rings at oil filter housing, and 4 more o-rings on the 2 VANOS solenoids. Viola! Oil leak no more and I'm poorer by less than RM270 - which includes my regular servicing. I brought my own oil, oil filter and air filter though....
And I must say that these guys are super pro! They even did a complete engine wash for me - meticulously cleaning EVERY item that has oil stain. Now my engine bay looks almost like new again! Hahaha!
If anyone here are feeling adventurous enough to head north to service your car, PM me for contact. Just to clarify, I'm NOT related to workshop in anyway. Just a happy customer after saving 90% of what the workshops here tried to charge me...
Vansoh;994079 said:Have checked out and repaired the oil leak issue... similar to what viperjet had encounter in 2012
refer: http://www.bmw-sg.com/forums/bmw-3-series-owners/54529-e90-engine-oil-leak-experience-14.html
what happened to mine was
1) the “flange" was over tighten previously by some WS thus causing the screw threaded plug that is attached to the valve cover to became loose and leak.
2) Vacuum Pump Leak.
Solution:
1) change valve cover (@$520).
2) Replace 2 O ring for vacuum pump
3) replace spark plug other O rings
4) cant remember whats number 4....
Total Cost: @$700 before GST.
Downtime: @ 3hrs
Valve Cover out
location of the Flange ( picture courtesy of Viperjet's post)
Flange that is spolit.
location of Vacuum pump ( picture courtesy of Viperjet's post)
Greentea;996863 said:Hi, can someone pls PM me the contact tel and address of this JB workshop pls. Am also having oil level low issues on my e90. Every few weeks, the car signals engine oil level is low. Dunno where the oil went to. No oil leaks seen on the ground. Evaporated? Read that many of you here have similar issues. Is this a sign of bigger problems coming?
Ric1970;997359 said:Hi OSCAR, can you kindly pm me the details to the JB workshop too. Need to get my E90 checked as well. Thanks in advance! cheers!
seanskye;992435 said:Woodland is good enough, there is an outstanding doc there. Hope you rectify the problem without further issues!![]()
