helbreath;701820 said:After reading some of the comments, i am rather confused. From what i understand 9" and 10.5" refers to the width of the rims, but some of you are referring it as the offset. The +30 and +35 the shop quoted is the offset. I think if you adjust the offset for the rear wheel to +40 it should be better.
1 2 mod, must learn learn. Nothing drop from the sky. Since i m frenly bro, i drop this for u:Puffer;701812 said:Is irritating and confusing how internet draws too much varying reports... Sigzzz... Stocks rims are best
Puffer;701953 said:called tyre shop ...clarified...and thanks to all the bros here for explaining to me or confusing me(kidding)....
I have run a check on BBS USA site application so will go for a 20 inch x 9J ET29 non stag set up..rather than the smaller 19inch stag set up. I guess i have to sacrifice a bit of cosmetic to accept my preferred CHR on my F10.
here's the funny thing...tyre shop says because 20 x9 is a big rim..if i want i can fit 275/30 on it too...is that right?
Puffer;701701 said:unless tyre shop smoke me....but they insist BBS set up is ET35 with 10.5. they told me if not change to non-staggered and all on 245/35/20 tyres. ET29 with 9inches rims[/QUOTE
Why didnt you opt for the non stagger all round with 245/35/20 tyre? since they did offer you the option?
Or may be you just Like the way the back wheel BIG and sticking out?
Purposely on negative camber?chopardgtxl;702001 said:I m running on chr 20 inch too
My ride is lowered..
I tried ferrying 2adult n 2kids behind so far no issue at all..
So far no problem, only the tire wall looks slighty slanted but to me it's ok..
That's why AC323 said stock is d best.roberttan;702003 said:just see the BBS site
Japan BBS LM F : 85x20 ET32 R : 95x20 ET37
RN F : 85x20 ET30 R : 95x20 ET40
But the BBS US retailer CHR F & R : 920 ET29
How do we know which is the correct off set? for BMW F10
even within the BBS family also come with not same offset for same size 20" rim
if you have to bring the rear wheel width down to 9 x 20 or 9.5 x 20 keep the existing tyre 275 you will see your tyre goes inside your wheel well than you may find it not aggressive
