Re: Gearbox Solenoid Change - Jerking Problem Solved - E90
Nattsg;1085168 said:
But since i took the ride i only have noticed that at times when i am at stop in D mode and my foot on the brakes, the car some times will jerk forward. I read online there are things like its the e90 legacy (its like that), the soleniods, reprogramming, atf flush or the soft stop issue etc.
When i gt my ride same issue... after ws coded it.. no mre jerking
Aaron_BMW;1085282 said:
Yes, I am guessing u have the same problem.
It's not serious and easy to repair.
Additionally I want to share with u some servicing guide:
Normal servicing
- engine oil
- oil filter
30K KM
- air filter
40K KM
- gear oil
- gear oil filter
100K KM / 200K KM / 300K KM
- spark plugs
- water pump
- brake hose
- starter
- compressor
- fuel pump
- air-con / alternator belt
Yearly
- air-con filter
Every 2 years
- coolant
Based on worn off
- brake pad
- Tyres
- battery
The rest is upon break down then replace
Hope this helps u....
Based on my experience, water pump is to be changed every 50k km.
Good reminder on water pump change at 50k interval. The part is only $70 last I bought one and it may lead to so much other issues if engine overheats,
Aaron bro. Can share with me where you do your gear box?
list of parts your changed?
Labour cost?
Parts cost?
Thanks
Labour cost?
Parts cost?
Thanks
Ok, PM u now....
Aaron, thanks for providing the workshop contact.
I thought I was hearing some noise from my gearbox, so visited them yesterday. Was planning to replace atf and oil pan but mechanic told me it's due to wear and tear of some plates, nothing to worry about and replacing atf and oil pan may not get rid of the noise.
In the end I didn't do anything as my gearbox is running smooth.
I jumped the gun and bought the oil pan beforehand, am now willing to sell it for a discount to anyone planning to service your gearbox.
http://www.bmw-sg.com/forums/3-seri...ieds/85530-wts-e90-transmission-oil-sump.html
Don't mean to hijack your thread, but I think I won't be using this part anytime soon so would rather benefit someone who needs it instead of letting it collect dust in the store room.
The mechanic who served me seemed knowledgeable, I will be going back there for some other issues.
U should change the oil pan with 7L gear oil every 40,000 KM.
Usually takes 1 or 2 years time to hit 40K KM depending on usage of car.
For me, is less than a year
Can pls advise when changing water pump, is there substantial dismantle of other parts in order to access the water pump? Bit worried end up weakening other parts in the process of water pump change....tks..Mine's > 100K kilo liao..
Don't think so, it's all access from the bottom directly.
while going at a very slow speed 10-20 km/hr and when i let go the gas pedal, the car will have this jerk feeling and a slight "tong" sound, although not often but very "pek che".....
what could be the cause?
i just had the valve body serviced....
This is interesting.
Please have ur car checked and let us know too?
This is where it is.....
U should change as ur mileage is due for water pump change and best before it breaks down
You can remove this by disabling the NIC (neutral idle control). Look for Codewerz
Good thing my doctor is not like that ......
open me up and see first - diagnostics no use ?
BMW engineers put in all those sensors for show only ya ?
Aaron_BMW;1080932 said:
U see, the gear box problem cannot be solved if u don't put ur car at a workshop to have it taken out and see if any parts needed to be replaced.
I need u to drive ur car down to ur own preferred workshop and have it fixed.
By calling up and giving the error code cannot solve ur gearbox problem.
Ouch ...... :slaphead:
Codewerz bro any advise ?
Aaron_BMW;949025 said:
thanks
of course not~!
I am driving a 2008 320i with GM gearbox. I recently started to experience jerking at low gear change...from 1st to 2nd gear. Workshop told me it's mechatronic problem and need to replace. He also mention that GM transmission doesn't have solenoid like ZF transmission, therefore need to change the entire mechatronic. Is this true?
Sent you a PM bro .....
Whether it's true depends on the ws reputation
