Hi all, just owned a pre-owned 2009 E90 model 318i near to 6 months. Mileage 110k. Just did servicing and ATF change.
Need views from all experts here as this is my first BMW. I experienced 1st gear to 2nd gear change very abrupt,( like gear engage very forcefully) when engine is cold. Recently, the gear symbol appeared when I was stationary at traffic lights. I managed to drive a little (less than 20m) to stop at road side, shut down and restarting engine, the symbol was gone till now. My Mechanic highly recommends a overhaul at 1.8k. Is it really needed and reasonable for me to go for it?
Secondly, I notice engine oil(suspected) dripping under the carriage. Position is slightly in the middle, after the front wheels. Please advise!
One of the lvl 1 WS at Sin Ming Autocare. Friend recommended. Hope to have 2nd opinion before plunging in. Thanks!Which ws did u go?
As long as engine is warmed up, it won't jerk so hard, that's what I realised.Does the abrupt gear change still occur? Can always get second opinion at BVO before you decide.
09 320 gm gearbox. Mine was engine oil leaking. Changed oil filter, pan, gasket.
For the jerk, i went to 2 workshops to solved it. They plugged in to obd and did some setting wch when asked they both said nothing. For first ws, my car felt responsive and finally went to 2nd ws my gear jerk is minimal.
Hi bro,My E60 also had sudden "transmission failure" recently even tho I changed the solenoids 8 months back. Leakages came back even tho almost all the engine seals, vacuum pump and flywheel stuff all changed.
Changed the oil filter housing and cooler gasket and this solved the leak (last change of oil filter housing gasket was like 10months back, so I guess the real culprit was the oil cooler gasket)
Next up is the O2 sensor which I suspect should be the one giving me the transmission problems (especially when the engine is cold). Getting it changed this friday, hope it will help.
Been reading the posts on the solenoid fix. Would like to have the address and contact number if any of you still have them. Have tried pm Aaron but I Guess he's no longer active here.
Also, a ball park for the parts and labour would be perfect.
Thanks in advance.
Best regards.
Hi Merci,
Do you have the ws contact already? If you do, can you pm me please? I am having the same problem as everyone here.
Thanks in advance!
Got it. Thank you Hayasahoshi!Have PM u
