Meek;1054986 said:Cleber ppl no need paper one.
Zak;1056279 said:I am using Mobil 5w-50 for my E92 325i. Not sure if I am using the correct rating. Any advice?
So far so good in terms of EO temp
Zincman;1056568 said:So can i say that BMW LL01 spec engine oil is better to use in singapore?
lf37;1071924 said:Hi brother, thank you for the info, have you try 0W/40? Thought for the hot ambient temp and turbo hot engine grade 40 maybe better.
Ahbengdriver;1071962 said:I have 2 questions:
1. So far I ve been using 30weight EO on my 335 only bcos that's the recommended spec. Whereas I use 40wt on my 320 as 'recommended'. In fact 5w-40 is poured into my 320. Ok, so can I use 30wt EO like this GC 0w-30 on the 320 or is it too light an EO for that N46 engine?
2. I ve heard of people losing EO in new BMWs (so cannot be those valve seal issues). One chap I know uses EO from SPC which obviously is not of BMW LL01 or 04(well cant trust the PRCs) ! Ok so my question is - if you use a 'lousy EO', does the EO 'evaporate' over time and hence gives the impression that the EO is lost?
E60F30;1074532 said:First post here![]()
Read through the entire thread. Decided to buy my own oil and bring it to pml.
First off, from the previous posts, I understand that EO with higher viscosity is recommended for forced induction engines while at the same time the engine would be better lubricated by EO with lower viscosity when cold starting which is usually when most of the shearing happens?
Mine is a 328i, so I'm not exactly sure which oil to pick.
Considering between GC w/titanum and GC w/syntec. Since mxtrading only carries 5w30 for GC w/titanium, would it be too thin for my engine? As for GC w/syntec they have 5w40 which is thicker.
Anyone tried royal purple? Read a PDF somewhere comparing premature shearing between various engine oil and royal purple was one of the top oils in that article. Can't seem to find it though.
Hopefully can get some advice from the pros lurking here.
lf37;1075335 said:A ex-Castrol staff told me there should not be any difference between GC and Singapore C!performance wise they are identical. Key is to change oil regularly, like every 10000 km. today's engine with forced feed air runs hotter thus regular oil change. 0W-40 is better as Singapore ambient temp is also higher.
