tlkchew
Re: How good K&N air filter??
Car Filter Review
found the link.. quite intresting.
APexi came out tops sorry...
Car Filter Review
wt_know;437338 said:although K&N is able to pass more air compare to stock air filter, however, is there "more than enough air" in the stock airbox to be passed ?
the weakest link is the stock airbox that has a limitation for incomnig air. hence, any type of performance drop in air filter is not able to produce any gain not due to the filter but due to lack of incoming air through the stock air box.
am i right ?
pengful;437410 said:Makes sense so get an air scoop to channel more air into the airbox instead of letting the engine suck air in.
Did my air scoop mod and I must say it did help make the car more active to acceleration.
wt_know;437416 said:i will also do the air scoop. the big question now is after the air scoop, should i continue to use the stock air filter or K&N drop in. based on e90post discussion & dyno, stock air filter works equally good if not better than any performance drop in filter in stock airbox.
tlkchew;437431 said:get a after market filter like KandN or Hurricane. otherwise you put new scoops in also no use as the stock filter can only move so many CUft of air/min
am i right ?
wt_know;437434 said:i wonder how many CUft of air/min pass through the stock airbox and whether it exceeds the CUft of air/min of the stock air filter as the whole airbox and air filter was designed by BMW R&D
tlkchew;449587 said:Doesnt that sleeve add extra restriction to the airflow? I would remove the sleeve altogether, even with the stock filter.
i guess when you purchase a new stock filter, it should come with the sleeve.
I am not sure what you mean by "that answer "how good is K&N filter" but its damn good!
