wt_know
Re: How good K&N air filter??
thanks for the 2cents advice. very chim ... i have to google brownian motion and read up to understand the logic. kekeke
kmolth;449695 said:Filtration quality is dependent on the following:-
#1 removal rating? e.g. 5um at 99+% efficiency?
#2 surface area of filtration media?
#3 resistance of flow? differential pressure
Good filter are meant to choke (plug up), if it doesn't choke... either the environment is very clean or the filter media removal rating is bigger. E.G. OEM rating let say is 5um at 90% eff. it maybe 10 or 20um rating.
To have lower restriction of flow without compromising contaminant removal, you need to increase surface area of filtration media. Oil in my opinion is not require in the filtration media, brownian motion of small particle will help adhere the particle to the fiber.
Just my 2 cent to consider if you are looking into upgrading.
