On pure city drive consumption, it is still enough to drive from SG -> KL -> SG.Codewerx;1081651 said:But cannot go Malaysia leh ..... Unless bring 2 jerry cans ?
detach8;1081693 said:Totally. In city traffic with speeds averaging below 30kph I am already getting almost 800km on 1 tank. Less than 30kph is really bad traffic, I usually do around 35-36kph averages but recently doing abit more peak hour traffic. Once I get back on my usual routine I'll see if it goes above 900-1000km. Pretty sure it would do that on NSHW. The diff ratio on the diesel is tall and at 110kph the engine is doing less than 2,000 rpms.
Ninja;1082050 said:detach8, your FC superb...what model is ur ride?
Codewerx;1082067 said:I think your ride can adjust the EGR - that should help make the FC even more efficient .......
detach8;1082076 said:Reduce or increase EGR?
Codewerx;1082089 said:Increase ..............
detach8;1082097 said:That would cause more gunk to build up in the intake tract, no? Also lowers combustion temp... how does that help with FC? I thought it was for emissions.
Codewerx;1082099 said:That would get less exhaust gas into your combustion chambers and increase efficiencies..........
Redirecting exhaust gas back into your engine while displacing fresh air - yikes ...... And getting the Diesel engine tuned as well would get some more mileage .....
detach8;1082123 said:Huh sibey confused. Increase EGR = increased exhaust gas recirculation = MORE exhaust gas into intake. No? My understanding wrong meh. For efficiency, it should be reduce EGR.
My only concern is that the reduction in EGR (i.e. LESS exhaust recirculated into the intake) would mean higher emissions and would also cause the DPF to clog up faster. This may be counter-intuitive if the car keeps doing a passive regen of the DPF by injecting fuel into the exhaust.
Let's take this offline bro... will buzz you soon. Very busy this and next week (due to a shorter week).
MW;1082132 said:What? We still discussing FC?
