jon2367;463296 said:I used K&N panel filter before. The difference in throttle response is immediately noticeable. But this comes at a price. The ducting after the MAF has a film of dirt on it and soon my throttle body started sticking. Looks like K&N allows very fine particles thru - not enough to damage the engine. But the oil from the filter sticks everywhere along the path of the airflow and dust sticks with it as well. I'm back to paper filter and change them often.
jon2367;472356 said:Its hard to determine whether its overoiled or not. I only did one pass with the spray then let it sit on crushed newspaper to soak up any excess. In any case the filter is pretty much toast now. At the last change I noticed a puncture in the wire gause, which in turn made a hole in the fabric. Don't know what it was it sucked up.
I've been back to OEM filters for over 2 years now. I change the filter at every 2 oil changes whether or not its clogged.tjy;472647 said:wow... a puncture doesn't sounds good ... but i've nvr heard of punctured filter, even for those on paper filter which is much easier to puncture.. time to get it changed bro !
Hon;473087 said:I bought the cleaning kit. Reach home happily pop open the bonnet, locate the airbox and start staring at it hard. No idea which screws to loosen.
No idea what is drop-in or cone type, I can't see anything beneath the airbox. I'm driving a E90 320i.
tjy;472789 said:can buy the K&N cleaning kit and clean yourself.. i believe it should be under $30... what type of filter are you using ?? drop in filter or cone type?? if is drop in, it is damnn easy to remove .. or wat u can do is to ask the person to clean it for you during servicing... but some of them actually don't oil it for you. They just use the air jet to spray it clean.. but u will be able to see how they remove it ..
How long did you last changed your stock filter?dreammaker;473338 said:I just change my stock filter to a K&N filter this morning. For E90 320i it is cone type.
Stock filter was very dirty....after changing to K&N I can feel that the engine is more responsive
achee;473537 said:How long did you last changed your stock filter?
