Kelleners Sport
Re: Kelleners Sport
sunstorm;875468 said:
Hi Singsider,
Does your car come with paddle shifters?
I understand from speaking to MA parts specialist that F20 has 2 transmission. The sports transmission and the normal one.
Only the sports transmission can be fitted with paddle shifters.
You used your vin correct? What if pml 118i has a different transmission? I know that pml transmission for the 118i is the non-sports version as I was trying to retrofit paddle shifters.
Yes i used my VIN. You can try it too - real oem bmw website. After entering your vin, look under automatic transmission. You should see a model number with 8hp45 in it. Only applies to auto, not manual.
Sent from my GT-N7000 using Tapatalk 2
Re: Kelleners Sport
Forrestgum;871199 said:
TRD aka Throttle Response Device aka Sprint Booster is a custom tuned throttle control unit from Dr Hannson. It has 22 customised settings to tweak the responsiveness of the throttle. Can be quite addictive if your resistance level is low.
hi bro, can i add TRD with swiss chiptech. is it compatible?
Re: Kelleners Sport
They're both different devices for targeting specific parts of the performance or response.
Long story short is YES
Re: Kelleners Sport
leslie11;875620 said:
Is yours going to be a Monster car soon?
Bro sunstorm we look forward to your monster ride next week.
Sent from my GT-I9300 using Tapatalk 2
Re: Kelleners Sport
are there any other brands to recommend bro? i am quite noob on this. currently i am on swiss chiptech, i just want more response and acceleration upon stepping the acceleration pedal.
Re: Kelleners Sport
I wish I could but my car is stock atm.
Give the guys here a day or two to reply, they're a really friendly bunch with needle sharp teeth that inject deadly poison.
Re: Kelleners Sport
Bro freedom, how is the swisstech? Got alot of diff wen start off n linear speed? Yrs from coco?
Re: Kelleners Sport
No lah, I think if want Monster car must change too many things to support ;)
I did put on a tuning box though. As Forrestgum shared with me, the difference is huge!!
erm ... at least from my perspective as well.
Hopefully by the GTG it will have adapted. But seriously, if you're going to do mods and Stage 1 is out due to no ECU tuning options, the tuning box is a must do best ROI thing.
Re: Kelleners Sport
leslie11;876007 said:
Can u describe your tune? How is the low end?
Definitely feel more torque in the low end even at low rpm. The map is not too bad but definitely going for fine tuning (with dyno).
Will need to let the adaptation kick in over the next few days.
Re: Kelleners Sport
Sunstorm, why don't you start a new Monster tune thread so we don't OT from the Kelleners tune.
Re: Kelleners Sport
Good idea. I'll post up somemore sharing when the car has adapted.
Just to wrap this up, I asked for the same things when I asked for my Jetta tune.
"Must beat Sonata cab from traffic lights" LOL
Re: Kelleners Sport
leslie11;876067 said:
This is the funniest thing i've heard all day.
You will be surprised that some uses sonata cab as a benchmark to determine whether the car or chip is good. ..
Re: Kelleners Sport
Did some research.. the Sonata 2L CRDI (comfort Sonata cab) runs at around 305nm. However, its kerb weight of 1660kg is substantial. So if a F20 116i can hit 300nm from say 1500rpm onwards, it should smoke a Sonata anyday, given its lower kerb weight of 1385kg. :)
Re: Kelleners Sport
At the green light, the Sonata may pull away cos of it's superior torque n diesel's burning properties, but you'll catch up as your superior BHP takes over n the diesel's burning fizzles out.
But I wouldn't race with a cab driver anyway, waste of fuel n a danger to others.
99okmeme
