delrosa81
Just thought I would compile the list of things that could go wrong in this model so everyone can have an idea what could be wrong.
Mileage: 114444km,
Age: 4 yrs old
1) Coolant was leaking, needed topping up once every 2 to 3 months as OBD would prompt. Was rectified during my automatic transmission change.
Mileage: 73,000km approx.
2) Automatic Transmission (Replaced under warranty). Normally auto transmission starts to give problems around 100,000km mark, I was unlucky I guess.
Mileage: 80,000km Approx
(FOC under warranty, if need to pay is approx. $8,000 to $10,000)
3) Windscreen Washer fluid motor. Water level kept falling and OBD kept prompting water level low. The fluid motor pump was replaced and problem solved.
Mileage: 93,000km Approx.
$90.00
4) Vanos Sensor and Engine Oil filter housing oil seals replaced.
Mileage: 106,000km approx.
$200++
5) Tensioner Pulley was abit noisy and replaced.
$200++ IIRC
6) Aircon Fan Coil leaking and was replaced.
Mileage: 106,500km approx.
$980.00
7) Engine Oil Sump and Engine Oil pump leaking, oil sump gasket replaced, Engine Oil Pump oil seal replaced.
Mileage: 114,444km approx.
$573.00
8) Radiator hoses, top and bottom replaced and flushed + change Thermostat and thermostat switch.
$526.00
9) Engine Mountings going to give up soon. Now need to rest first, Vitamin M running very low.
TBA
10) Alternator Bearing. There is wong wong sound coming from the bearing, so this will need to source and be replaced as normally the whole alternator would be replaced.
Replaced: S$ 120.00.
11) Oil Seperator and relevant hoses to be replaced. Still pending replacement.
Mileage: 116,000km
Replaced: Approx. S$ 400.00
12) Engine Flywheel Oil Seal Replacement + ATF + ATF Pan + ATF Oil Filter Replacement.
Mileage: 128,000km
Replaced: Approx. S$1067.00
13) Radiator + Some Hardened Water Hoses Replacement
Mileage: 129500km
Replaced: Approx. S$1027.00
Its a non exhuastive list and for any existing owners, it would be something you might want to take note off. You can also add on to the list.
My car is almost all repaired and done up, so anybody interested to buy? :lol2
Mileage: 114444km,
Age: 4 yrs old
$90.00
$200++
$200++ IIRC
$980.00
$573.00
$526.00
TBA
Mileage: 116,000km
Mileage: 128,000km
Mileage: 129500km
