My E90 320i Repair Journal
Re: My E90 320i Repair Journal
Those with gear jearks, try changing ATF?
I sold my '06 silver 320i... i wonder who bought it. its gearbox was in perfect condition.
Anyone know if an e90 door can be realigned? Mine seems to be slightly off and window will "tick tick" when driving. Quite irritating at times.
What U mean by tick tick? If its somewhat similiar to creaking sounds, try the 3m tape on your door seals.
As for alignment of the door, I think its difficult to align till perfect though.
Riposte;709637 said:
Hmmm, i just got a 06 320i, when i brake there is a slight jerk forward. nothing else so far, any idea whats going on? or what i should do?
Many thanks in advance!
For this issue, PML tried the following fixes:-
1st: Reset Transmission. I understand there is some settings or timing thingy where it can be reset to default. This will result in a smoother gear shifting and minimise frequency of the hard brake come to total stop jerk.
2nd: Reprogram, I guess to update firmware or something like that. Seems to be better for awhile
But then if problems persists, get the workshop or PML to give the transmission the once over again. Not necessarily that the gearbox must be replaced. An ATF change might do the trick though.
Many thanks to start with.
Earlier today I went to a pro-BMW workshop, a sitesponser, with my problem, was told a $150 reprogramming should do the trick. The workshop told me it was a success, however during the journey home, the slight gentle jerks during breaking just before a complete halt return, seems like it has problems during down shifting of gear. The workshop told me to try for a few days. And break for a solid 15seconds at traffic lights??
On a side note,
Changed nology sparrk plugs for $160 w labour
BMC air filter for $130
PIAA wiper blades for $119 ( wipers were real hazard to driving in the rainy season now)
Also they said my top and bottom oil gaskets are leaking, quote me about $750 to replace
And some water hoses leaking too another 2-300$$$.
I guess thanks to delrosa81 I can officially be part of this 320i repair journal haha:woowooo::woowooo::woowooo:
Just replaced my stock starter motor $680 & battery $250 which up the lorry at the same time. Both items already over 6-yrs after travelled 77k
On a side note,
Hmmm but I feel BMW slush boxes are never absolutely seamless. When it is brand new, the shifts are really seamless but once you use it for awhile, the gear shifting would get more pronounced. The jerk forward when U come to a complete stop might be an indication of a problem.
But the real problem for me came when I noticed the reverse gear would delay in engaging. I noticed that when I engaged reverse, the transmission would take at least 2 to 3 seconds before it engages reverse. When it comes to a day where the transmission does not engage then the transmission have "died".
My top and bottom gaskets was also replaced, the radiator hoses as well.
Welcome to the club! :p
Care to share what are the symtoms of the starter motor going kaput? Any different cranking sound or whatsoever?
GB in my E39 uplorry 2 mths ago. Still engage & got drive. It got slower & slower & ..........
oic, so u sent for repairs yet? Mine totally could not engage reverse, in the end towed in to replace. sighs.
Seems bmw auto transmission cannot last for very long.
My E39 almost end of 8th yr. Sent it to Propel loh. My mileage around 160k km.
Longevity of BMW GB is a subject matters that has been discussed for the longest time.
I thought my E90 can last until I change to my next car soon but last 2 weeks I replaced the entire cooling system from radiator to hoses/water pump, thermostat etc etc and mileage only 60k....
Last week the door power lock failed on me and need to change the locking regulator assy....I register for the FT86 preview..and who knows I may like it,,,since its my second car...
There are 60 GT-86 available for booking.
MTL.
Actually I also not sure what is the symtoms also..
I have been driving my car almost everyday & I do noticed that if I leave my car for a day or two, I'll need to press start button 2 or 3 times in order to start the engine.
Recently I went for a holiday. After came back, I tried to start my car but totally can't eventhrough all the lighting & other gadgets is working fine.. after towed to workshop, they informed me that the starter motor had to be replaced (without suspecting any problem with the battery).. but after replaced the starter motor, still couldn't start & they found out that the factory fitted battery also go kaput! So end up changed the battery as well.
After that, very easy to start the car!!:dance:
So I think for starter motor.. when you start to find it difficult to start (like need more than one or twice).. you have to standby to change the starter motor liao
How about gearbox?? Anyone can advise/experience what is the lifespan of the E90 gearbox? Think that is what I concern most!
i think its 130,000 - 150,000 Km. But proper maintenance can prolong the life. I will be replacing gearbox oil and pan/filter every 40,000 Km, due to constant city traveling. If i am not mistaken even the Honda civic FD series gearbox requires the same sort of maintenance. So its not just BMW, its the modern high performance gearbox characteristics
Subject of GB lifespan has been subject of discussion for the longest time. There is no firm answer.
Other than proper maintenance.. so think is whether you heng sway or not.. when strike toto also dunno :shakebon:
So for GB replacement is normally new one or re-con or any OEM?
What is the typical price at sponsor workshops for new and re-con?
how much did the GB cost u from Propel?
pg88comim
