Whisky_Tango said:Im just sand bagging the results. As Im taking 2.2L with 223CFM @ 6K rev, so with 15CFM extra from ADM (238CFM) it might not be much. So Im considering that the ADM power curve will eventually meet the stock power curve at around 6K rev.
As for snowman's car, there's about 53CFM extra. Definately the power curves at 6k rev will not meet but the gains might be marginal as compared to lower revs.
Hope this clears up.
Shaun said:Bro, it is not going to meet at 6000 RPM even in the 2.2L scenario. Try running the math. 15 CFM still exceeds the requirement. What the engine needs, it is providing and then some (whatever rated pressure is). Read again about maintaining pressure differential. I'm not quite sure why you continue insisting it is going to be choking off or meeting stock power when the theory clearly shows that it won't. Real life dynos of engines beyond 2.2L and similar redlines have also proven this.
Tanzy said:Just got back from Pasir Gudang. Saw some cars with the ADM charger. Couple of Getz and a Civic. The VTi Civic with the fan wasn't any faster than a stock VTi. Really no difference at all.
Crufty Dusty said:Before anyone goes crazy and starts fantasizing about building all sorts of crazy power, remember that FI is still the preferred way to go since all the plumbing, flow reversion, reduction of charged air temp issues etc have been taken care of.
Whisky_Tango said:Well... tats because im not experience in this field and truly your time & inputs are well received by me. Only through such discussions will I learn and hope you still continue to support.
Hopefully others will find this discussion meaningful.
Cheerio...![]()
Shaun said:The main thing is that these electric chargers are only designed to operate at low pressures and relatively low volumetric flow.
They don't have charge temp issues because they are moving so little air at so low an RPM and are not conducting heat unlike with turbos. They don't have flow reversion either because there is no increase in exhaust manifold pressure unlike with turbos of all but the largest sizes. I don't see issues in plumbing either because the flow levels are only slighly bumped and there is less restriction in the absence of an intercooler.
Shaun said:IIRC these fans are WOT-only fans so they cut off then throttle is lifted. Besides low pressure, they are also low RPM, low inertia fans that stop very quickly - all relative to TC. In the case of ADM variable speed.. I don't know what happens when you lift, but it is likely they're reading TPS and don't bother pushing the system against a closed TB cos that only wastes energy and service life. So IMO compressor surge won't be an issue.
Why would you think an MAF would be hurt by some fan noise being such a simple system? The stock engine bay is already a harsh environment.
Crufty Dusty said:OK, so let's say engine flow demand is 200cfm, this device flows 300cfm of air, throttle plate closes, where does the 100cfm of air go but back through the MAF sensor? Anyone know for sure how much pressure we're talking about here?
Certain Karman Vortex MAF systems are extremely susceptible to noise and vibration which would cause inaccurate MAF readings. Some cars on this system are known to completely stall out when on the drag strip and the other vehicle revs its engine very hard. The resulting harmonic vibrations on the intake cause turbulent air to be misread by the sensor.
Shaun said:ADM doesn't list a pressure rating. Bilge blowers are commonly 300-500 CFM @ 0.5 - 1.5 PSI.
Shaun said:Oh I was thinking more hotwire MAF. Which other cars besides the Evos run karman vortex? I thought most stuff is hotwire these days?
Crufty Dusty said:According to Bernoulli's equation this figure only applies for steady flow which is not the case here.![]()
Mostly DSMs. Hotwire or hot film is popular these days most likely due to sensor cost alone.
