Updates from our Garage!
Revol Carz Makeover
Trusted Sponsor
Congrats Mr Lim for changing car to a BMW X6M and always choosing us as your preferred garage for all your car servicing needs
Please feel free to contact us at 6555 1181 if you need any assistance or advice. Or you can visit our website www.revol.com.sg for more information about our services.
Meanwhile at our 2nd garage our team have accomplished to compete this BMW x5 engine overhaul!
Stay tuned as our team gears up to mount up the engine back into the engine bay!
Same white colour but different brand logo! All cars are welcome in our garage :)
Car servicing is all about preventative maintenance. A regular service schedule can save you major expensive repairs.
Arresting parts that need to be replaced before they fail, for example, cooling hoses, timing belt, water pumps, radiator not only keep you safe but also saving you money in major breakdowns.
Generally there are two types of car servicing. The minor service is required every ten thousand kilometers. The major servicing is generally every thirty to forty-five thousand kilometers.
The best guide for the car owners is to refer to the manufacturer’s manual.
Don’t ignore regular preventive maintenance servicing.
At Revol Carz Garage, our certified mechanics resent unscrupulous touch-and-go bad attitude. Some workshop resort to hurried and easy servicing job with quick oil and filter change and go.
When we service your car, we go through a carefully orchestrated procedure of double-checking and maintain every part of your car in our servicing protocol.
We communicate with the car-owner for any worn-out or broken parts before replacing.
Our integrity and uncompromising workmanship are important to keep our loyal customers coming back.
Feel free to book your next Car Servicing through Revol Carz Garage hotline 6555 1171. Our competent mechanics are passionate about ensuring your car is safely on the road.
Revol Carz Garage is located at
10, Ang Mo Kio Industrial park 2A,
# 02-18 Ang Mo Kio AutoPoint.
All cars serviced or repaired at Revol Carz Garage receive a complimentary car wash and full interior vacuuming
Hi Everyone,
Thank you so much for your continuous support!
Starting a busy week ahead after a great weekend!
Do feel free to drop by Revol Carz Garage at 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
You may also SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
Your car engine top is a removable metal valve cover so the mechanic can access the valves for adjustment. The valve cover has a gasket packing (usually made of rubber or cork) which seals the cover to the engine, keeping any oil from leaking out.
If the gasket is worn out, engine oil will leak, causing the engine to lose oil. Running the car too long without the gasket replacement can cause serious engine damage.
Common symptoms indicating your valve cover gasket needs replacement are;
• Oil is leaking.
• Debris and oil around the valve cover.
• Whiff of oil smell coming from the engine when you drive.
• Oil found in the spark plug wells.
To find out if your valve cover gasket is OK, simply pop up the hood to look at your engine.
If you are unsure, don’t hesitate to drive to Revol Carz Garage and let our BMW trained professional mechanics inspect your car.
Revol Carz Garage is located at.
Hotline 6555 1171
Feel free to contact Gavin Tan at HP: 9740 6855 for his dedicated personalized services if you need any assistance regarding your car repair and maintenance
Hi Everyone, thank you so much for your continuous support! Starting a busy week ahead after a great weekend!
Regular servicing is the key preventive maintenance measure in keeping your ride happy, safe and saving you money in the future.
Generally there are two types of car servicing. The minor service is required every ten thousand kilometers. The major servicing is generally every 60k.
Don’t ignore regular preventive maintenance servicing. Arrest a small fault before it becomes a major problem that burns a huge hole in your pocket.
At Revol Carz Garage, we resent unscrupulous touch-and-go attitude of some workshop resorting to easy short-cut servicing job with hurried oil and filter change and go.
We double-check and maintain every part of your car systematically in our servicing protocol. We communicate with the car-owner for any worn-out or broken parts before replacing.
We replaced one of the PDC (Parking Distance Control) buzzers defective during car servicing of an Audi A5.
Our integrity and uncompromising workmanship keep our loyal customers coming back.
For your next oil change, please feel free to drop by our Revol Carz Garage at Blk 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
You may also SMS / Whatsapp to our Workshop Manager, Gavin at 9740 6855 for friendly and absolute no obligation consultation.
What a productive week for Revol Carz Garage!
Please feel free to drop by our Revol Carz Garage at Blk 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
Your mechanics should check your brake rotors at every major servicing performed on your BMW.
Generally the lifespan of a BMW rotor is 1.5 times that of the brake pads.
Although it is not necessary to replace them together, it is prudent to do so because the rotors don't last long enough to completely "skip" a car-servicing cycle.
Inspect your brake rotors for cracks, scoring or pulsation when braking. Visually, the brake rotor may look good but still be worn out.
A good sign that the brake rotors are worn out is finding ridges around the edges.
Not sure if your brake pads and rotors are worn out yet? Don’t hesitate to visit us for an inspection at
Revol Carz Garage,
10 Ang Mo Kio Industrial park 2A,
Our certified mechanics are specialized in repairing BMWs and continental cars.
Feel free to contact Gavin Tan at HP: 9740 6855 for his dedicated personalized services if you need any assistance for your car repairs needs
Hi Everyone,
Arresting parts that need to be replaced before they fail, for example, cooling hoses, timing belt, water pumps, radiator keep you safe.
At Revol Carz Garage, our certified mechanics shun unscrupulous touch-and-go scam. Some workshop resort to hurried and easy servicing job with quick oil and filter change and go.
Blk 10 Ang Mo Kio Industrial Park 2A,
All cars serviced or repaired at Revol Carz Garage receive a complimentary car wash and full interior vacuuming!
Hi Everyone,
First two days of the week have been packed after a great weekend!
The vehicle’s brake pads are literally undergoing extreme stress every time you put your foot on the brake pedal to slow down or stop the car.
The brake pads squeeze the disc at high temperature until the vehicle comes to a halt and they do this repeatedly for thousands and thousands of kilometers until they fade.
Your car’s manufacturer probably recommends a specific kind of brake pads. There are numerous types of brake pads depending on your intended use. From soft type for normal use to harder and aggressive for racing applications.
Signs and symptoms your car needs a brake repair or brake pads replacement.
• Brake warning light comes on and stays on.
• Grinding or squealing noise when you apply the brakes.
• Your vehicle pulls to one side when you brake.
• The brake pedal not responsive and feels spongy.
• The brake pedal goes to the floor or requires excessive pressure.
• Your last brake pads replacement exceeded the manufacture’s recommendation.
Do you hear brake-grinding or squealing noise when you apply your brake? Do you feel vibrations or pulsation when you press down the brake pedal?
If any of these symptoms occur to your car, we can regain your confidence of smooth braking. At Revol Carz Garage, our professional mechanics are also highly trained in replacement of highest quality original brake pads.
Don’t ignore your brakes. If you are unsure, please visit us at Revol Carz Garage at Blk 10, Ang Mo Kio Industrial Park 2A, # 02-18 Ang Mo Kio Autopoint
You may reach us at SMS/WhatsApp to our Workshop Manager, Gavin at 9740 6855 for a friendly and absolutely no-obligation consultation.
• Oil is leaking.
To find out if your valve cover gasket is in good condition, simply pop up the hood to look at your engine.
If you are unsure, don’t hesitate to drive to Revol Carz Garage and let our professional mechanics to check for you.
We will carry out replacement or repair only upon your approval of our fair and transparent quotation.
Hotline 6555 1171.
Feel free to call our friendly Workshop Managers, Gavin Tan at HP: 9740 6855 for his dedicated personalized services if you need any assistance about your car.
If you see an “Oil Sensor Warning” (yellow can graphic) lighted on your dial while you’re driving, it is wise to pull up safely at the nearest stop to check the dipstick to confirm your safe oil level.
If the oil level is fine then most likely the sensor is faulty.
The persistent warning light will certainly annoy any driver. The oil level sensor is not difficult to replace but it is best to leave this to your mechanic.
If the “yellow oil can light” is annoying you, just drive up to Revol Carz Garage and let our experience mechanics check the sensor and respective electronics for your car.
You may reach us at 6555 1171 or SMS/WhatsApp to our Workshop Manager, Gavin at 97406855 for a friendly and absolutely no-obligation consultation.
The key role of the shock absorber is to keep the tires in constant contact with the road surface, which ensures safe control and braking response from your vehicle.
Shock absorbers are hydraulic devices that help to control the impact and rebound movement of your car’s springs and suspension thus smothering out bumps and vibrations.
You know your shock absorbers are due for replacement with the following symptoms.
• Your drive feels spongy.
• Longer stopping distance.
• Swerving and nose dives during your drive.
• Vibrations.
• Your car sliding and veering across the road in mild cross winds.
• Rattling, rock and roll over uneven surfaces.
• Uneven tire wears.
If you can’t tell if your shock absorbers are still road worthy, feel free to drive to Revol Carz Garage for a complete inspection. Our location is at;
You can reach us at 6555 1171 for an appointment or SMS/WhatsApp to our Workshop Manager, Gavin at 9740 6855 for a friendly and absolutely no-obligation consultation.
Car servicing is all about preventative maintenance. A regular service schedule can save you from expensive major repairs.
Discovering ailing parts that need to be replaced before they fail, for example, cooling hoses, timing belt, water pumps, radiator not only keep you safe but also saving you money in major breakdowns.
At Revol Carz Garage, when we service your car, we go through a carefully orchestrated procedure of double-checking and maintain every part of your car in our servicing protocol.
Blk 10, Ang Mo Kio Industrial park 2A,
Hi Everyone,
Having a productive week again after a great weekend!
The coolant “Spare tank” or reservoir is usually a robust clear plastic container that “catches” the excess or overflowed coolant when the radiator system is pressurized and boiling hot. The reservoir spare tank is attached to the radiator and engine with hoses. It is the only place where you can fill coolant instead of directly into the radiator.
Since the spare-tank is made of plastic, it is prone to crack over time or if your car is involved in a front accident. Any leak in the reservoir will cause the lost of coolant thus quickly overheating and damage the engine.
If your dial shows the coolant temperature rising abnormally fast, you might have a coolant leak.
Best thing is to pull your car to the roadside if possible and investigate your spare tank.
Call Revol Carz Garage at 6555 1171 for car breakdown rescue. If it is not possible to repair your car at site, we will arrange a tow to our workshop and have replace the damaged part/s replaced immediately.
If you are unsure of your “spare-tank” and the overflow hose are good condition, don’t hesitate to drive up to Revol Carz Garage and let our experienced mechanics inspect or replace them for you.
Our workshop is located at:
Or contact us at 6555 1171.
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and interior vacuuming.
