Updates from our Garage!
The key role of the shock absorber is to keep the tires in constant contact with the road surface, which ensures safe control and braking response from your vehicle.
Shock absorbers are hydraulic devices that help to control the impact and rebound movement of your car’s springs and suspension thus smothering out bumps and vibrations.
You know your shock absorbers are due for replacement with the following symptoms.
• Your drive feels spongy.
• Longer stopping distance.
• Swerving and nose dives during your drive.
• Vibrations.
• Your car sliding and veering across the road in mild cross winds.
• Rattling, rock and roll over uneven surfaces.
• Uneven tire wears.
If you are not sure whether your shock absorbers are working properly, feel free to drive to Revol Carz Garage, Blk 10, Ang Mo Kio Industrial Park 2A, # 02-18 Ang Mo Kio Autopoint for an inspection.
You may reach us at 6555 1171 or SMS/WhatsApp to our Workshop Manager, Gavin at 9740 6855 for a friendly and absolutely no-obligation consultation.
All cars serviced or repaired at Revol Carz Garage receive a complimentary car wash and full interior vacuuming
A regular preventive maintenance servicing with spark plug replacement can help to keep your car running its optimum and our competent mechanics are passionate about ensuring your car is always safe on the road.
Feel free to contact us and book for your next Car Servicing at 6555 1171.
All cars serviced or repaired at Revol Carz Garage receive a complimentary car wash and full interior vacuuming.
Have a great week ahead!
A fresh new week has arrived and a busy one too! Happy Tuesday!
Do feel free to drop by Revol Carz Garage at 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
You may also SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
The automatic transmission fluid in BMWs is said to last a “lifetime”. However according the ZF, Manufacturers of BMW transmissions, they recommend replacing the ATF every 60,000 kilometers.
If you are unsure when you had the last service, replace the fluid as soon as possible will extend the life of your automatic transmission.
Check your car manual to determine the type of transmission fluid for your car.
ATF (Automatic Transmission Fluid) fills your automatic transmission as well as the torque converter. Unless the old ATF is drained by a flushing machine, don’t expect to flush all the old fluid out. It is general acceptable that some old ATF inside the torque converter will remain and mixes with the new fluid.
Unsure when to replace your Automatic Transmission Fluid? Let our experienced mechanics do the job for you. We will also conduct micro-check for leaks amongst other essential inspection.
Please don’t hesitate to visit us at Revol Carz Garage!
# 02-18 Ang Mo Kio AutoPoint
Hotline 6555 1171.
Feel free to contact our Workshop Managers, Gavin Tan at HP: 9740 6855 for his dedicated and personalized services if you need any assistance regarding your car repair and maintenance.
If your car has been running poorly, misfiring and stops erratically during the drive, it is possible that you have bad ignition coils.
The most common symptom of ignition coil failure is caused by worn out spark plugs. A faulty ignition coil also causes the engine stall abruptly after the car runs for a while.
If you have been annoyed with these symptoms, let us inspect the ignition system for you. There may be other hidden causes too.
Please don’t hesitate to drive to our Revol Carz Garage at
# 02-18 Ang Mo Kio Auto-point.
Or contact us at 6555 1171.
You may also SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation. We’ll make your drive a happy one again.
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and interior vacuuming.
The owner of the BMW 740Li perspired profusely when he drove up to Revol Carz Garage complaining that his car air-conditioning was blowing torturing hot air. Our air-conditioner specialists promptly diagnosed that the Cooling Coil was faulty.
The Cooling Coil is also referred to as evaporator coil or heat exchanger in a car air conditioning system. It is usually located deep inside and under the dashboard or under the instrument panel hence extensive and time consuming works is involved to dismantle it.
The aluminum Cooling Coils are similar to radiators which consist of a series of internal tubes with fins attached to them. Like the radiator, air can pass through the fins. The internal tunes carry moving refrigerant or Freon.
Cooling Coil failures commonly point to leakage. This commonly occurs because of caustic corrosion, decomposition or welding joints deterioration. The evaporator fins are also subjected to clogging from debris and leaves over time.
Inevitably a leaking Cooling Coil should be replaced promptly.
If you have any issue in any part of your car, do feel free to contact us. We will always serve you with the best of your interest!
Hotline 6555 1171.
A regular service schedule can save you major expensive repairs. Discovering any failing components that need to be replaced before they break down, for example, cooling hoses, timing belt, water pumps, and radiator keep you safe.
Don’t ignore regular preventive maintenance servicing.
When your car is serviced at Revol Carz Garage, we go through a carefully orchestrated procedure of double-checking and maintain every part of your car in our servicing protocol.
We communicate with the car-owner for any worn-out or broken parts before replacing.
Our integrity and uncompromising workmanship are important to keep our loyal customers trusting us and coming back.
Feel free to book your next Car Servicing through Revol Carz Garage hotline 6555 1171. Our competent mechanics are passionate about ensuring your car is safely on the road.
Revol Carz Garage is located at
You may also SMS / Whatsapp to our Workshop Manager, Gavin at 9740 6855 for friendly and absolute no obligation consultation.
It is mid-week and we are not slowing down! Time check: 10:41AM we see more cars checking-in for car servicing and car repair services.
Thanks guys for your support
Starting off with an awesome week with a full packed house and an energized Team of specialists all revved up to serve you for the day!
Awesome Monday with an awesome turnout of cars checking in for car servicing and car repair services! Feeling grateful and privileged to have your support in Revol Carz Garage!
Have a great day ahead!
Engine/transmission mountings hold the engine to the car body or to the sub-frame engine cradle.
Typically, the engine and transmission are both bolted together by three or four mountings.
In order to reduce the engine vibration felt inside the vehicle, the mountings are filled with rubber so that is no direct metal to metal contact between the engine and the car body.
Although the engine/transmission mounting need no maintenance, they need replacement when the rubber part breaks or separates.
The most common symptoms of a failed engine/transmission mounting are excessive vibrations and engine noise felt inside the vehicle.
If you have been feeling the discomfort of vibrations in your car, the engine or transmission mountings are due for replacement. You can relax while our professional mechanics do the diagnosing and replacement for you.
You’re invited to visit us at Revol Carz Garage,
Blk 10, Ang Mo Kio Industrial park 2A
Or contact us at 6555 1171 for an appointment.
You may also text / WhatsApp to our Workshop Manager, Gavin at 9740 6855 for friendly and absolute no obligation consultation.
Are you noticed your car’s headlights and dash lights becoming dim lately? It could mean your alternator has become weak. Don’t’ risk stalling your car on the highway.
Please feel free to drop by our Revol Carz Garage at Blk 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171 for a safety check.
Monday is here again! Take advantage of this fresh new week by checking a few things off your to do list! If you've been holding off your car servicing and car repair needs, we can help you!
At Revol Carz Garage, we assure our customers that every car battery replaced by us is properly installed with the important battery registration coding on the IBS.
To find out more information of Revol Carz Garage car servicing packages, Please feel free to drop by our Revol Carz Garage at Blk 10, Ang Mo Kio Industrial Park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
You may also text us by SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
BMW 750i sent in our workshop for Rear suspension checking. And replaced with the original BMW Air matic and Air Pump.
It's a brand new week with a busy as usual appointment and we are sincerely grateful for all the overwhelming customer support given in choosing US as your preferred car servicing centre!
Have a lovely day ahead!
This is Mr. Chua’s super-car, Audi R8. It arrived at Revol Carz Garage with two issues to address. The air conditioner blows hot air and the side skirts needs some respray touch ups.
The Audi is raised for under-carriage inspection and checking whether the air-conditioner pipe is leaking.
With our updated diagnostic handset, we read various Fault Codes pertaining to the air-condition system.
Our sharp-eyed Audi Specialist narrowed down to faulty air con expansion valve.
We replaced the air con expansion valve and the issue solved and putting on a smile on Mr. Chua’s face.
The gearbox is one of the most vital components of any motor vehicle. Shifting problems or sudden skip in the gear can be a cause for concern. The transmission of the vehicle is subjected to wear and tear due to exposure to extreme heat and frictions.
At Revol Carz Garage, we offer complete services from engine repair to any transmission problem. We have updated diagnostic equipment and expertise to pinpoint the fault in the gearbox such as, burning smell, leaks, worn clutch. Gearbox repair or replacement is complicated and is best performed by professional mechanics to ensure safe and optimum performance.
Let us show you our expertise in overhauling the gearbox of a Volkswagen Cross Polo at our Revol Carz Garage recently.
