Re: Valve Seals & Valve Cover Gasket change – white smoke problem solved – BMW E90
Bro Aaron,
Pls PM me details of Francis' workshop, labour cost to change, stockiest cost.
Many thanks!
Bro Aaron, thanks for the info and prompt response. Appreciate very much :)
richardteh;1066521 said:
Bro Aaron,
Many thanks!
Hi, have about the same problem. Can you provide the stockist and workshop name and contact? Thanks.
No problem. Have a great new year
Ok, PM u now......
Hi Aaron can pm me the details too. Thank you!
Ok, PM u now
Hey, I have the same but much less severe problem, can you please PM me how much it cost you for parts and labour?
Ok, PM u now...
Thanks to Bro Aaron, I got my problem solved today! When the mechs opened out my engine I was glad to see a relatively sludge free engine.
I changed engine valve seals, valve cover gaskets, vacuum pump gaskets, oil filter holder gasket, oil change and oil filter change and also changed the oil separator and all hoses.
I am a happier 3 series owner now!
Hi bro alvin, what a clean engine you have.
Lol I'll been topping up 1l of oil every week because of my oil leak issue, that is why the engine clean clean..
Ha,
That's funny
I hope my engine will be as clean as yours. I've been doing the same too for the past 1 month. 1l every week.
Golden brown is a good color
Hey Aaron, can you pm me the stockies as well as the repair workshop and cost of it? Thanks!
Not sure if my case is similar to yours but i have been experiencing 1l engine oil lost every 1k-1.5k. Recently, i found out there is a small sludge of yellow substance in my coolant which i believe is oil. I've also experienced random and occasional engine stall at while waiting for light to turn green
Engine stall = problematic. Must really find the real cause behind
Hi Aaron,
Thanks for posting this thread on the valve seals issue. I am having the same problem , please pm me the details for the repairs example - Stockies shop location and prices for valve seals and gasket / workshop name and location with labor cost (excluding the stockies) etc. I shall look forward to your reply. Thanks!
Best Regards,
Godspeed
Hi Zeals and Godspeed, i've PM you the info from Bro Aaron.
All the best...
Sure,
I can PM u.
I believe u r facing multiple problems
ok365ok365com
