Chris Chew
Re: Weird Sound on my E90
Hi... The problem you sites is at constant speed and this is irrespective of engine and gear selection ... This is not tires or bearings because they do not produce sounds at a narrow speed band ... The only part that can cause this is the front propeller bearing which is the 3 rd item that rotates at road speed and the wear can cause resonance at a fix speed .. It is not expensive but seldom fails on the E90 ... Change this and you should resolve the problem .. Cheers
