An engine running on unleaded petrol builds up a great amount of pressure inside the enclosed crankcase. This pressure is released by a Vacuum Pump.
The vacuum pump tends to impact the emission and exhaust system as it fires continuously in each cylinder inside the engine. If not properly maintained, it can cause significant damage to cylinder head components and the engine loses fuel efficiency.
When there is a build-up of burnt fuel, the new fuel burns less efficiently thus reducing the engine performance.
Symptoms of a failing vacuum pump include;
Poor fuel efficiency;
Difficulty pressing the brake pedal;
Oil leak;
Air conditioner not working.
If you notice your car runs with poor fuel efficiency, drive up to Revol Carz Garage and let our certified mechanics inspect your engine, hoses and vacuum pump for any leak.
A BMW 120i had its Vacuum Pump successfully replaced at Revol Carz Garage, solving its fuel deficiency problem.
New vacuum pump ready for replacement.
Cheers,
Best Regards,
Revol Carz Garage Admin Team
@ Ang Mo Kio
Tel: 6555 1171
With the advancement of automobile technology, replacing the car battery in a modern smart-car is no longer a straight forward job.
We pay very close attention when it comes to changing car batteries for cars like the BMWs.
When we replace a battery, the BMW’s electronic system needs to register an IBS (Intelligent Battery Sensor). The smart-car power management software and intelligent battery sensor need to know when a new battery is installed, battery capacity, battery type, current mileage reading and that the charging profile is accordingly adjusted, etc.
Failure to register the replacement would confuse the car to charge for the old battery. Similarly, registering the charging profile for an incorrect battery would cause premature failure.
If you drive a BMW, it makes sense to let the professionals replace the correct type of battery with IBS registration. At Revol Carz Garage, we recommend the most ideal and correct battery and are proficient in ensuring your car electronic systems are IBS registered.
Is your car battery is due for replacement? Revol Carz Garage will give you the best advice and right type of premium brand battery.
A BMW 740i had a battery replaced with IBS Registration at Revol Carz Garage.
The battery replacement job is followed by careful safety inspection of the undercarriage and maintenance.
Premium battery is ready for replacement.
Feel free to contact Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance regarding your car repair and maintenance
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Wishing Everyone A Selamat Hari Raya!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
It can be really frustrating if your car cannot start especially when you are getting late to work. If the battery is not depleted, the blame could fall on the starter motor.
To get an engine started, it must be turned (or cranked) at some speed so that it sucks air and fuel into the cylinders and compress them. A powerful electric starter motor does the turning job.
Starter failures are not all caused by a faulty starter motor although some common failures are contributed by worn out carbon brushes, poor contact points or the armature bearing and weak battery.
The starter motor itself may fail due to other internal parts. If the starter is faulty, it should be replaced
If you experience problems in the starter system, your mechanic may need to measure the starter electrical control circuit as the first step.
You can get help immediately with the problem resolved professional at Revol Carz Garage.
Call our hotline at 6555 1171 for help or contact Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance on your car repairs needs
A BMW 523i has the Starter Motor replaced at Revol Carz Garage.
New starter motor waiting to be replaced.
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and interior vacuuming.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Car Servicing
We all know how important it is to maintain our vehicles to ensure long, trouble free motoring and safety.
Don't risk damage to your vehicle's engine and other components. A regular service schedule can help keep your car running its best and saving you money (from hefty repairs cost) in the future. Detecting a small fault before it becomes a major problem that burns a huge hole in your pocket.
Generally there are two types of car servicing. The minor service is required every ten thousand kilometers. The major servicing is generally every thirty to forty-five thousand kilometers.
The best guide for the car owners is to refer to the manufacturer’s manual for the recommended car-servicing intervals.
Be wary of “touch-and-go” car-servicing gimmicks. Don’t be scammed by quick-and-cheap services. Compromised inferior filters, maintenance parts and lube (from bulk) can seriously damage your engine in a long run.
At Revol Carz Garage, our work is performed to the highest standard. We go through a carefully orchestrated car-servicing procedures, thoroughly checking and maintenance on every part of your car. We supply only premium brands lubricants and OEM service parts that meet or exceed your vehicle manufacturer's specifications
Is your car due for the next oil change? Call our hotline, 6555 1171 to book a car-service appointment.
Feel free to contact Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance for your car repairs needs.
Another BMW 523i is on schedule for car-servicing at Revol Carz Garage.
Besides lifting the car for servicing work, we check the undercarriage to ensure all components are in good condition.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
AUTOMATIC TRANSMISSION FLUID or in short, ATF is used in vehicles with automatic transmission. ATF typically comes in red or green to distinguish it from other fluid in the vehicle.
The transmission fluid is optimized for the requirements of a transmission such as gear lubrication, valve operation, torque converter and brake band friction.
The modern day ATF contains a wide variety of chemical compounds and additives to improve lubrication qualities such as rust and corrosion inhibitors, anti-wear additives, detergents, dispersants to protect and clean metal surfaces and more.
Synthetic ATF that offers better performance and service life is also available in the after-market.
Check your car manual for the recommended ATF changing cycle your transmission. Most workshops recommend changing it every 80,000 TO 100,000 kilometers.
If you are in doubt of whether your vehicle needs replacement of Automatic Transmission Fluid or what type to use, don’t hesitate to consult with our experienced mechanics at Revol Carz Garage.
Feel free to contact Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447. They will be honored to render their dedicated personalized services.
A BMW 730i visited Revol Carz Garage for Auto transmission fluid replacement
ATF pan leakage.
New ATF pan awaiting replacement
ATF replacement in progress
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
The car radiator is one of the many components in the cooling system that requires proper maintenance in giving the engine a longer life.
When a radiator begins to deteriorate, the engine tends to overheat when you drive a high speed. Although the overheating is not always pointed to the radiator, it is always good to first check the radiator and the coolant side tank for cracks that cause loss of engine coolant fluid.
Warning! Never attempt to open the radiator cap when the engine is hot lest you get badly scalded from boiling coolant.
If you are unsure, drive up to Revol Carz Garage and let our experienced mechanics do a thorough check for you. We will only proceed to repair upon your approval of our fair and transparent non-obligatory quotation.
Feel free to contact our Workshop Managers, Gavin Tan (HP: 9740 6855) or Randy Phuang (HP: 9851 1447) for their dedicated personalized services if you need any assistance regarding your car’s issues.
A BMW 330CIACABRIO had its radiator successfully replaced at Revol Carz Garage.
The BMW is lifted for radiator replacement work followed by extensive safety inspection and maintenance.
The leaking radiator is to be dismantled.
New radiator awaits replacement.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Wishing All a Happy National Day!
Happy Birthday Singapore!
Cheers to the 53rd Years of Independence!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Control arms and their integrated ball joints are some of the most crucial components on a BMW suspension system. It literally controls the wheels and suspensions as they go through a range of motions during drive.
Most control arms consists of an inner and outer ball joint made of plastic, rubber and metal and lubricated in grease with a rubber boot to seal it from the outside. The grease inside the housing can evaporate or become contaminated from moisture and foreign particles.
As the ball joint is worn out, it can result in excessive movement inside the housing and your steering and handling of the car become less précise. In extreme scenario, the ball joint can separate from the control arm completely.
A faulty or worn control arm or ball joint is dangerous and life-threatening and should be be replaced at regular intervals.
If you feel your steering and handling of your car is somewhat slacking, please come to Revol Carz Garage for a check by our professional mechanics to be safe.
A BMW 730Li visited Revol Carz Garage for front lower control arms replacement
The lower arm ball joint rubber is already worn out.
New Front lower control arm replacement awaiting replacement
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Wishing you and your family a Selamat Hari Raya Haji!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
A BMW 640i came for Timing Gear Replacement
Hi Everyone,
The function of your BMW timing gears is to allow the camshaft and crankshaft to turn the timing chain. The pistons are moved up and down by the turning of the crankshaft which also allows the intake and exhaust valves on the cylinders to open and close. These components are important for optimum engine timing.
As the piston moves downward, the intake valves open to allow fuel and air into the cylinders. As the piston moves upward, the exhaust valves open to expel exhaust air from the cylinders.
If the intake valves are not functioning properly, the correct air/fuel mixture will be able to enter into the cylinders. If the exhaust valves are not opening and close properly, exhaust air will be trapped inside the cylinder.
If the timing gears are failing, the valve timing and ignition timing will not be accurate. Noises from the engine compartment may occur, causing the engine to run rough, backfire or stalled.
We hope you will enjoy viewing the following pictures.
The BMW 640i was towed to Revol Carz Garage for diagnosis.
The car was lifted for accurate diagnosis and thorough safety and functional inspection.
The original BMW parts spread next to the worn-out ones, ready for replacement.
The new timing gear set was professionally replaced by our BMW specialists.
The timing gear replacement job was completed after our QC team successfully conducted a running test.
Preventive maintenance is always better than repair. It is important to understand about wear and tear before the components break down totally.
If you have any issue in any part of your car, do feel free to contact us. We will always serve you with the best of your interest!
Thanks for reading!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
The automatic transmission fluid (ATF) in some cars lasts a “lifetime” but it is a good idea to replace the fluid every 90,000 kilometers.
If you are unsure when you had the last service, replace the fluid as soon as possible will extend the life of your automatic transmission.
Check your car manual to determine the type of transmission fluid for your car.
ATF (Automatic Transmission Fluid) fills your automatic transmission as well as the torque converter. Unless the old ATF is drained by a flushing machine, don’t expect to flush all the old fluid out. It is general acceptable that old ATF inside the torque converter will remain and mixes with the new fluid.
Unsure when to replace your Automatic Transmission Fluid? Let our experienced mechanics do the job for you. We will also micro-check for leaks amongst other essential inspection.
A BMW 320i arrived at Revol Carz Garage for Auto transmission fluid replacement
The car is lifted for routine safety checks and maintenance including the ATF replacement.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
A blower motor comprises of a motor and a fan that regulates air flow into the passenger cabin through the vents.
Over time, a blower motor may become noisy due to the electrical contact wear and tear. Before installing a new blower motor, pull it down to inspect if there is something stuck in it. Also check the fuse and relay.
Worn out carbon brushes in the motor may also cause failure.
If your blower is abnormal, don’t hesitate to drive your car to Revol Carz Garage. Our experienced mechanics will check and advise you if any part replacement is needed.
A BMW 525i had its air-conditioner blower motor professionally replace at Revol Carz Garage.
The new air-conditioner blower motor is ready for replacement.
The air-conditioner control module is on standby for replacement.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
If you are unsure, please drive up to Revol Carz Garage and let our experienced mechanics do a thorough check for you. We will only proceed to repair upon your approval of our fair and transparent quotation.
Feel free to call our hotline, 6555 1171 or contact our friendly Workshop Managers, Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance for your car repairs needs.
A BMW 523i replaced an original radiator at Revol Carz Garage.
The vehicle is lifted for radiator replacement work followed by thorough undercarriage safety inspection.
The radiator is leaking
New radiator awaiting replacement
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Valve Cover
Your car engine top is a removable metal valve cover so the mechanic can access the valves for adjustment. The valve cover has a gasket packing (usually made of rubber or cork) which seals the cover to the engine, keeping any oil from leaking out.
If the gasket is worn out, engine oil will leak, causing the engine to lose oil. Running the car too long without the gasket replacement can cause serious engine damage.
Common symptoms indicating your valve cover gasket needs replacement are;
Oil is leaking.
Debris and oil around the valve cover.
Whiff of oil smell coming from the engine when you drive.
Oil found in the spark plug wells.
To find out if your valve cover gasket is OK, simply pop up the hood to look at your engine.
If you are unsure, don’t hesitate to drive to Revol Carz Garage and let our trained technicians do the inspection.
OIL COOLER
The engine oil cooler is usually of water-to-oil heat exchanger that allows the engine to remove excess heat from the oil.
Heated engine oil is fed to the oil cooler from an adapter located between the engine block and the engine oil filter. The heat absorbed by the cooling system is transferred to the air as it passes through the radiator.
The oil cooler, though normally lasts a life-time. However, like any mechanical component, it is subjected to wear and tear despite careful maintenance.
Below are a few of the symptoms that the oil cooler may need replacement.
  • Coolant in the engine oil.
Coolant in the oil pan can damage the engine.
  • Oil leaks from the oil cooler system.
Built within the adapter is an o-ring or gasket. Failed adapter may force engine oil out of the engine. You may notice a puddle of oil on the ground under the vehicle.
When an engine loses oil level, it loses the ability to lubricate itself leading to increased engine temperature and premature parts failure.
  • Coolant leaks from the oil cooler.
External oil cooler failure may force engine coolant to leak from the engine. Coolant leaks from the oil cooler may result in overheating and mechanical component damage.
If your car has any of the above symptoms, it will require both the oil cooler and the engine oil to be completely flushed of all contaminations. The oil cooler and adapter, if failed will require replacement.
Don’t wait for further damages to set in. It is advisable to contact a professional mechanic quickly.
At Revol Carz Garage, our professional team of mechanics have decades of experience and are ready to give your car, possibly the best rigorous checks and repair professionally.
Feel free to contact Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their prompt, dedicated and personalized services if you need any assistance for your car repairs issues.
A BMW 320i drove up to Revol Carz Garage for Valve cover gasket and Oil cooler (with gasket) replacements.
The vehicle is lifted for repair works followed by thorough undercarriage safety inspection.
The valve cover gasket is leaking
Valve cover gasket replacement in progress
New valve cover gasket awaiting replacement
New oil cooler gasket awaiting replacement
New oil cooler awaiting replacement
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and vacuuming.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Another BMW 528i is serviced at Revol Carz Garage.
We lifted the BMW for car-servicing works
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Happy Deepavali 2018
Diwali or Deepavali also known as the “festival of lights”, is an ancient Hindu festival celebrated in autumn every year. The festival spiritually signifies the victory of light over darkness, knowledge over ignorance, good over evil, and hope over despair.
Wishing you and your family Happy Deepavali!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
VALVE COVER GASKET REPLACEMENT.
Oil is leaking.
If you are unsure, don’t hesitate to drive to Revol Carz Garage and let our trained technicians perform their professional inspection with the right equipment.
Feel free to contact our Workshop Managers, Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated and personalized services if you need any assistance regarding your car repair and maintenance.
A BMW 528i dropped by to Revol Carz Garage for Valve cover gasket replacement
After the valve gaskets had been carefully replaced, our eagle-eyed mechanics lifted the car up for thorough safety checks and provided maintenance works.
The failed cover gasket is leaking.
Valve cover gasket replacement is in progress
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
When your coolant pump begins to leak or becomes noisy, your car tends to overheat at low speed or idle. However, when you accelerate, the engine temperature drops. Leaking water pump can result in damaging the drive, timing belt or cooling system.
Although it is not always indicative of a coolant pump failure, it is a good starting point to check the radiator hoses first. If there is no leak and no pressure, it indicates the coolant pump is failing. Never attempt to open the radiator cap when the engine is hot lest you get third degree burn by boiling fluid.
If you suspect your car has a failing coolant pump, drive to Revol Carz Garage for an immediate inspection. Our experienced mechanics can accurately diagnose the root of the problem/s. We will proceed to repair your car only upon your approval of our fair and transparent quotation.
For the safety of our customers and our guarded integrity, we supply only premium OEM or original quality parts for your car.
Call our hotline; 6555 1171 for your car related assistance
Have a chat with our friendly Workshop Manager, Gavin Tan HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance for your car repairs needs
A BMW 640i A receives a coolant pump replacement at Revol Carz Garage.
After the coolant pump is replaced, our technicians conducted 360 degree safety inspection and preventive maintenance.
New coolant pump awaits replacement.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
The brake rotor must be able to absorb the heat and friction under braking and can withstand warp. Don’t compromise your safety with inferior brake rotors which are made of cheap metals and can warp, causing brake pedal pulsation under braking.
Your brake rotors are key safety components essential to effective braking performance. They should be inspected at regular intervals for wear and cracks.
Your mechanics should check your brake rotors at every major servicing performed on your BMW.
Generally the lifespan of a BMW rotor is 1.5 times that of the brake pads.
Although it is not necessary to replace them together, it is prudent to do so because the rotors don't last long enough to completely "skip" a car-servicing cycle.
Inspect your brake rotors for cracks, scoring or pulsation when braking. Visually, the brake rotor may look good but still be worn out.
A good sign that the brake rotors are worn out is finding ridges around the edges.
Not sure if your brake pads and rotors are safe or worn out yet? Don’t hesitate to visit us for a professional inspection.
Our certified mechanics are specialized in repairing BMWs and continental cars.
Feel free to contact Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services anytime you need assistance for your car repairs/maintenance issues.
A BMW 520i had its brake rotors successfully replaced by Revol Carz Garage.
Worn out brake rotors are waiting to be replaced.
New brake rotors await replacement.
New brake sensors await replacement.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
