It can be very frustrating if your car cannot start especially in the morning when you are getting late to work. If the battery is not depleted, the blame could fall on the starter motor.
To get an engine started, it must be turned (or cranked) at some speed so that it sucks air and fuel into the cylinders and compress them. A powerful electric starter motor does the turning job.
Starter failures are not all caused by a faulty starter motor although some common failures are contributed by worn out carbon brushes, poor contact points or the armature bearing and weak battery.
The starter motor itself may fail due to other internal parts. If the starter is faulty, it should be replaced
If you experience problems in the starter system, your mechanic may need to first measure the starter electrical control circuit.
You can get help immediately with the problem resolved professional at Revol Carz Garage.
Call our hotline at 6555 1171 for help or contact Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance on your car repairs needs
A BMW 523i visited Revol Carz Garage for a starter motor replacement.
A brand new starter motor is ready for replacement.
New starter motor has been installed successfully
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and interior vacuuming.
Cheers,
Best Regards,
Revol Carz Garage Admin Team
@ Ang Mo Kio
Tel: 6555 1171
May your Christmas sparkle with moments of love, laughter and goodwill and may the year ahead be full of contentment and joy.
Have a Blessed Joyous and Merry Christmas to you and to your family!!!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
When your coolant pump begins to leak or becomes noisy, your car tends to overheat at low speed or idle. However, when you accelerate, the engine temperature drops. Leaking water pump can result in damaging the drive, timing belt or cooling system.
Although it is not always indicative of a coolant pump failure, it is a good starting point to check the radiator hoses first. If there is no leak and no pressure, it indicates the coolant pump is failing. Never attempt to open the radiator cap when the engine is hot lest you get third degree burn by boiling fluid.
If you suspect your car has a failing coolant pump, drive to Revol Carz Garage for an immediate inspection. Our experienced mechanics can accurately diagnose the root of the problem/s. We will proceed to repair your car only upon your approval of our fair and transparent quotation.
For the safety of our customers and our guarded integrity, we supply only premium OEM or original quality parts for your car.
Call our hotline; 6555 1171 for your car related assistance or visit us at;
Or have a chat with our friendly Workshop Managers, Gavin Tan HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance for your car repairs needs
A BMW 320i receives a Coolant pump replacement at Revol Carz Garage.
The BMW is lifted for brake rotors replacement work followed by routine safety inspection and preventive maintenance.
New coolant pump awaits replacement.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
May each day of the New Year be filled with good health, more opportunities, peace and abundance.
Wishing everyone to have a blissful and prosperous New Year...
Cheers to 2019!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Hi Everyone,
The gearbox (transmission) is one of the most vital components of any vehicle. Shifting problems or sudden skip in the gear can be a cause for concern. The transmission of the vehicle is subjected to wear and tear due to exposure to extreme heat and frictions.
The Mechatronics module performs complex shifts operations. The gearbox control communicates constantly with the engine control unit and the “communications” determines the ideal point at which to make a gear change.
In short, the Mechatronic components represent the brain of the gearbox.
If your car has any of the following symptoms, our experienced mechanics can help you;
1. Surging in Drive gear.
2. Surging in Reverse gear
3. Lurching off the line from a stop
4. Harsh 2 to 1 down-gear-shifts
5. PRNDS flashing.
6. Bad idling.
Revol Carz Garage offers a complete service on any transmission problem. We have updated diagnostic equipment and expertise to pinpoint the fault in the gearbox such a burning smell, leaks, worn clutch. Gearbox repair or replacement is complicated and is best performed by professionals from reputable auto-workshop for safe and optimum performance.
We hope you will enjoy viewing the following pictures.
A BMW 730i arrives at Revol Carz Garage for a total gearbox overhaul.
The car is lifted for 360 degree undercarriage safety inspection.
The whole gearbox is systematically dismantled from the car.
Extensive cleaning works begins.
This is how the ultra-cleaned interior of the gearbox looks after careful cleaning.
Here is another section of the gearbox after cleaning.
Components inside the gearbox are professionally dismantled.
The packing and repair kits are on standby for replacement at Revol Carz Garage.
The old and new Mechatronic components sit side by side waiting for replacement.
The replacement of Mechatronic components in progress
The Mechatronic components are now successfully installed.
Preventive maintenance is always better than repair. It is important to understand about wear and tear before the components break down totally.
If you have any issue in any part of your car, do feel free to contact us. We will always serve you with the best of your interest!
Thanks for reading!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Valve seal replacement
If you notice your car blows blue smoke while idling, chances are the valve guide oil seals in your engine have worn out.
Leaking oil is the most common symptom of bad valve seals. Leaks can damage or contribute to failure in the engine. If you find your oil level is low, the first thing is to check the valve cover and oil sump gaskets for signs of leaking seals. The valve seal leak can progressively worsen over time so it is urgent to replace.
Valve cover gaskets
One of the most common places to have an oil leak is the valve cover gaskets. The leak commonly appears in front of the engine or down the exhaust side.
Leak from the valve cover gasket can create a mess. Engine oil can seep into the spark plug holes and contaminate the ignition coils. Check the valve cover once the gasket has been removed. If you find hairline cracks, you will have to replace the metal valve cover and fasteners too.
If you find your car emitting blue smoke or the valve cover leaking with engine oil, drive up to Revol Carz Garage. We’ll jack up your car and have a thorough inspection by our experienced mechanics.
A BMW 318i had its valve seals replaced by Revol Carz Garage.
We lifted the BMW for repair works followed by safety inspection and maintenance.
Valve seals replacement in progress.
New original valve seals awaiting replacement
New valve seals had been successfully replaced.
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and vacuuming of the interior.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
BMW cars utilize an oil sensor located in the oil pan or dip stick. Its function is sending oil level information to the vehicle computer system. The sensor also has a pH detector which monitor the engine oil acidity which is communicated to the CBS (Condition-Based Service) system and displayed to the driver via the instrument cluster warnings.
Engine oil is the essential lubricant that maintains low friction among engine moving parts and additionally cools the engine. Your engine requires a minimum level of oil in its sump in order to circulate sufficient volume and pressure throughout the engine oiling system.
Engine oil picks up contaminants overtime. However, modern engine oils are designed with solvents, anti-acid components and detergents so that they can neutralize the contaminant loaded up to a certain point. Eventually, the ability of the engine oil to protect the internal engine parts from contaminants damage is depleted.
The sensor is prone to failure electrically or it can leak oil. When this occurs, a yellow oil warning light on the instrument panel illuminates.
If a warning light illuminates on your instrument panel, check the dip-stick to see if there is sufficient oil to continue your journey to your nearest auto workshop. To avoid damage to your car engine, we advise you to call Revol Carz Garage’s hot line for a tow to our workshop for our professional diagnosis.
A BMW 523i arrived at Revol Carz Garage for oil level sensor replacement.
The BMW is lifted for repair work followed by intensive safety checks.
New oil level sensor awaiting replacement
Oil level sensor replacement in progress
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Dear Valued Customer,
Please kindly be informed Revol Carz Garage will be closed from 5th Feb 2019 to 14th Feb 2018.
Business in our Ang Mo Kio branch will be officially open from 15th Feb 2019 (Friday) and Toh Guan branch will be open from 18th Feb 2019 (Monday).
We thank you for your continuous support!
Wishing you and your family a Happy New Year of the PIG, Gong Xi Fa Cai! May an abundance of good fortune, good health, happiness, success and prosperity be yours throughout the year!
chinese-new-year-2019_07f-jpg.67094
And of course, have a happy motoring too.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
The key role of the shock absorber is to keep the tires in constant contact with the road surface, which ensures safe control and braking response from your vehicle.
Shock absorbers are hydraulic devices that help to control the impact and rebound movement of your car’s springs and suspension thus smothering out bumps and vibrations.
You know your shock absorbers are due for replacement when the following symptoms occur.
  • Your drive feels spongy.
  • Longer stopping distance.
  • Swerving and nose dives during your drive.
  • Vibrations.
  • Your car sliding and veering across the road in mild cross winds.
  • Rattling, rock and roll over uneven surfaces.
  • Uneven tire wears.
If you can’t tell if your shock absorbers are still road worthy, feel free to drive to Revol Carz Garage
Or call our hotline at 6555 1171.
Feel free to contact our friendly Workshop Managers, Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance about your car.
A BMW 335i has its front shock absorbers successfully replaced at Revol Carz Garage
The BMW is lifted for the shock absorbers replacement work followed by safety inspection and maintenance.
Worn front shock absorbers waiting to be replaced.
New front shock performance absorbers awaiting replacement
New front shock absorbers have been installed successfully.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
The function of your BMW timing gears is to allow the camshaft and crankshaft to turn the timing chain. The pistons are moved up and down by the turning of the crankshaft which also allows the intake and exhaust valves on the cylinders to open and close. These components are important for optimum engine timing.
As the piston moves downward, the intake valves open to allow fuel and air into the cylinders. As the piston moves upward, the exhaust valves open to expel exhaust air from the cylinders.
If the intake valves are not functioning properly, the correct air/fuel mixture will be able to enter into the cylinders. If the exhaust valves are not opening and close properly, exhaust air will be trapped inside the cylinder.
If the timing gears are failing, the valve timing and ignition timing will not be accurate. Noises from the engine compartment may occur causing the engine to run rough, backfire or stalled.
If your BMW is running rough and noises are audible, pull up safely and call Revol Carz Garage’s hotline 6555 1171 for immediate roadside assistance. We will arrange for your car to be safely towed to our workshop and our professional mechanics will diagnose accurately with our modern auto equipment.
We will carry out repair only upon your approval of our fair and transparent quotation.
Revol Carz Garage is located at
10, Ang Mo Kio Industrial park 2A,
# 02-18 Ang Mo Kio AutoPoint.
Feel free to call our friendly Workshop Managers, Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance about your car.
A BMW 640i A has its timing gears replaced at Revol Carz Garage.
The BMW is lifted for repair works followed by intensive safety inspection and maintenance.
New Original timing gears set awaiting replacement.
New timing gears set are professionally installed.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
The automatic transmission fluid in some cars lasts a “lifetime” but it is a good idea to replace the fluid every 60,000 kilometers.
If you are unsure when you had the last service, replace the fluid as soon as possible will extend the life of your automatic transmission.
Check your car manual to determine the type of transmission fluid for your car.
ATF (Automatic Transmission Fluid) fills your automatic transmission as well as the torque converter. Unless the old ATF is drained by a flushing machine, don’t expect to flush all the old fluid out. It is general acceptable that old ATF inside the torque converter will remain and mixes with the new fluid.
Unsure when to replace your Automatic Transmission Fluid? Let our experienced mechanics do the job for you. We will also micro-check for leaks amongst other essential inspection.
Please don’t hesitate to visit us at Revol Carz Garage
Hotline 6555 1171.
Feel free to contact Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance regarding your car repair and maintenance
A BMW 523i dropped by at Revol Carz Garage for Auto transmission fluid replacement
ATF pan leakage
New ATF pan awaiting replacement
Auto Transmission Fluid replacement is in progress.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
You know your shock absorbers are due for replacement with the following symptoms.
  • Vibrations.
Revol Carz Garage for a complete inspection. Our location is at:
# 02-18 Ang Mo Kio Autopoint
Our hotline 6555 1171.
We will only carry out repair / replacement upon your approval of our fair and transparent quotation.
Feel free to contact Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated personalized services if you need any assistance for your car repairs and maintenance
A BMW 520i arrived at Revol Carz Garage for original shock absorber replacement
New original shock absorbers awaiting replacement
New shock absorber linkage awaiting replacement
Shock absorber replacement in progress
New shock absorber has been installed successfully.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Happy Labour Day 2019!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Your car engine top is a removable metal valve cover so the mechanic can access the valves for adjustment. The valve cover has a gasket packing (usually made of rubber or cork) which seals the cover to the engine, keeping any oil from leaking out.
If the gasket is worn out, engine oil will leak, causing the engine to lose oil. Running the car too long without the gasket replacement can cause serious engine damage.
Common symptoms indicating your valve cover gasket needs replacement are;
Oil is leaking.
Debris and oil around the valve cover.
Whiff of oil smell coming from the engine when you drive.
Oil found in the spark plug wells.
To find out if your valve cover gasket is OK, simply pop up the hood to look at your engine.
If you are unsure, don’t hesitate to drive to Revol Carz Garage and let our trained technicians perform their professional inspection using updated equipment.
Feel free to chat up with our Workshop Managers, Gavin Tan at HP: 9740 6855 or Randy Phuang at HP: 9851 1447 for their dedicated and personalized services if you need any assistance regarding your car repair and maintenance
A BMW X3 receives a Valve Cover Gasket replacement at Revol Carz Garage.
Worn valve cover gasket is leaking
New ATF filter ready for replacement.
New valve cover gasket awaiting replacement
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
A BMW 520i arrived with mechatronics failures.
MECHATRONICS” derives from a combination of the words, “mechanical” and “electronics”.
In the BMW’s design of the Automatic Transmission, for example, it uses an internal Transmission Control Module and Solenoid Package known as a Mechantronics.
Transmissions with solenoids are known to have problems over time and require the mechatronics to be replaced due to the solenoids being sealed as part of the mechatronics unit.
A BMW 520i in particular, experienced mechatronic failures in the transmission and headed to Revol Carz Garage for an overhaul.
Replacement of the mechatronics unit can be expensive. However, we source our original replacement parts directly from reliable sources which we then code to suit our customers’ BMWs.
Common symptoms for a failing Mechatronics :
  • Subtle jolt from gearbox when slowing to a stop.
  • 5th gear jolt when cruising at motorway speed.
  • 5th to 6th gear shifts are harsh.
  • Delayed engagement of reverse gear.
  • Transmission fail safe mode when shifting from 1-2 and 2-1.
  • Gear monitoring faults stored.
A BMW 520i arrives at Revol Carz Garage with mechatronics failures.
The car is lifted to access the mechatronics in the transmission box.
The mechatronics assembly overhaul in progress.
Mechatronics overhauling works in progress
Old and new mechatronics plates lying side by side.
Valve body pistons awaiting replacement.
Mechatronics overhaul is successfully completed.
Thanks for reading!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
The starter is one of the most important parts on your car. What happens when your starter fails and your engine will not start? You may try to crank the engine but nothing happens.
Before you blame it on your starter motor, make sure your battery is in good condition and is fully charged.
The starter motor itself may fail due to other internal parts. If the starter motor is indeed faulty, it is time to replace with a new and reliable one.
To find the cause of the problem in the starting system, your mechanics may need to measure the starter electrical control circuit.
Are you having difficulty starting your car? You can get help immediately when you call Revol Carz Garage at 6555 11171.
We are located at:
Blk 10, Ang Mo Kio Industrial Park 2A
Contact us at our hotline; 6555 1171.
You may also SMS / Whatsapp to our Workshop Manager, Gavin at 9740 6855 for friendly and absolute no obligation consultation
All cars serviced or repaired at Revol Carz Garage receive a complimentary car wash and full interior vacuuming
A BMW 523 XL had trouble with starting the car and our experienced mechanics at Revol Carz Garage replaced the starter motor.
We supply only genuine or quality OEM starter motor for replacement
New starter motor has been replaced successfully.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Some car owners claim that the ATF (Automatic transmission fluid) in BMWs last a “lifetime”. However according the ZF, Manufacturers of BMW transmissions, they recommend replacing the ATF every 60,000 kilometers.
If you are unsure when you had the last service, replace the fluid as soon as possible can extend the life of your automatic transmission.
ATF (Automatic Transmission Fluid) fills your automatic transmission as well as the torque converter. Unless the old ATF is drained by a flushing machine, don’t expect to flush all the old fluid out. It is general acceptable that some old ATF inside the torque converter will remain and mixes with the new fluid.
Let our expert mechanics do the job for you. We will also conduct micro-check for leaks amongst other essential inspection.
For your peace of mind, please visit us at Revol Carz Garage
Hotline 6555 1171.
A BMW 316I F30 dropped by to Revol Carz Garage for ATF Oil replacement
The BMW 316i is lifted in preparation for Automatic Transmission Fluid replacement.
It is recommended that the ATF pan be replaced. The pan on the left of the picture is a brand new replacement pan.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
The car air-conditioning is critical in keeping us cool and comfortable in our ride. The cooled gas chills the air inside the car’s cabin.
The car air-conditioner gets a lot of usage but we may not think much about the compressor working overtime to bring us comfort. The compressor does exactly what the name implies. It compresses refrigerant and sends it to your car’s air condenser.
Like other car parts, the compressor expects to wear and tear over time until no cool air is coming from the system.
Some common symptoms may be the compressor is low in refrigerant due to leakage or fan problem.
If your car’s air-conditioning ceases to blow cool air, don’t hesitate to visit Revol Carz Garage for diagnosis. We have the latest analyzer, scan tools and updated technologies and our certified mechanics will give your car air conditioner system a professional thorough check.
If your car’s air conditioning systems is not blowing cool air to your satisfaction, please don’t hesitate to drive up to Revol Carz Garage for an non-obligated inspection.
We are located at.
Hotline: 6555 1171.
Feel free to chat up with our friendly Workshop Managers, Gavin Tan at HP: 9740 6855 for their dedicated personalized services if you need any assistance for your car repairs and maintenance
All cars serviced or repaired at Revol Carz Garage receive complimentary car wash and interior vacuuming.
Another BMW 318i arrives at Revol Carz Garage for Air Compressor replacement.
Car hoisted up for safety check and maintenance before the air compressor replacement work commences.
To reach and replace the aged compressor, the dashboard steering wheel and console are professionally dismantled.
Alas, the bad air compressor is dismantled (bottom) whilst the brand new OEM high-quality replacement air compressor is on standby (top).
To get the air conditioning system running smoothly and cool like brand new, the cooling coil is recommended to be replaced. The one on the right is a brand new cooling coil.
The job is professionally completed with every component reassembled with precision, The air conditioning system now purrs like new with pleasant cool air.
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
Wishing Everyone A Selamat Hari Raya!
Cheers,
Best Regards,
@ Ang Mo Kio
Tel: 6555 1171
